Samsung S22C200B 21.5" 1920x1080 5ms VGA DVI VESA LED Monitor
Quicklinx: 9HLNWS00 Mfr#: LS22C20KBSZ/EN
Business monitors can be stylish as well as efficient. Your Samsung LED business monitor is designed with a very narrow bezel width, which delivers both better viewing and a more attractive look. Its compact, space-saving form will also help you to make the most of your working environment. You can also wall-mount it easily and achieve the best possible positioning. Thanks to Magic Angle technology, you'll enjoy a great visual experience from a wide range of viewpoints. The monitor even helps you reduce energy costs, as it consumes just 0.1 W while in standby mode.
  • Experience minimal design and maximum effect
    Maximize your monitor experience with the help of a chic narrow bezel. With its narrow bezel width, users benefit from reduced distraction when looking at the monitor and therefore can enjoy greater levels of concentration. The extra screen space also makes it easier to set up a dual monitor workstation, which also adds to work productivity. But for those who just want a smart looking monitor, the narrow bezel adds a sophisticated look and feel to any desk.
  • Keep your work space as efficient as your monitor
    If you need a work monitor that uses office space efficiently, then Samsung LED business monitor SC200 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SC200 is ready to deliver an efficient and clean work space. Optimizing your office space is now easily achieved with the Samsung LED business monitor SC200.
  • Maximize your space with easy wall mounting
    Give your monitor the best possible positioning with the VESA Wall Mount. Easy to mount and install, it is convenient, safe, compatible, and the perfect partner to your monitor. You will always have a great viewing angle and it also makes the most of your space with its slim design.
  • Upgrade to the next level with mega dynamic contrast
    Mega dynamic contrast ratio delivers new levels of color and picture quality to your viewing experience with images that are real-to-life. A breathtaking Mega DCR contrast ratio shows blacks at their absolute darkest and pristine whites and other colors at their brightest. You will notice the crystal clear picture clarity. It is like explosions of colors that make other screens seem dull in comparison. Enjoy your multimedia content with the professionalism it deserves.
  • Help business with cost-cutting technology
    Minimize your work costs with the help of the DPMS 0.1 W feature. It ensures that your Samsung business monitor only consumes a maximum of 0.1 W while in standby mode. This amazingly low consumption is beneficial both financially and environmentally, and is simply unmatched by competitors.
  • Samsung magic angle
    With 5-mode angle management, enjoy a full visual experience with amazing picture clarity from whatever angle or position you view your Samsung monitor from.
Samsung S22C200B - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.24825 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
Matte black
50.43 cm x 18.5 cm x 38.53 cm
3.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
CSA, UL, TUV, VCCI, C-Tick, GOST, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CSA 22.2 No. 60950, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, GB 4943, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, GB 17625.1-2003 EMC, KN22, KN24, K60950-1
3-year warranty
Display Type
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24825 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Power off timer, MagicTune, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
Matte black
50.43 cm x 18.5 cm x 38.53 cm - with stand
3.5 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-1/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.1 Watt
Included Software
Samsung MultiScreen
Dimensions & Weight Details
With stand - width: 50.43 cm - depth: 18.5 cm - height: 38.53 cm - weight: 3.5 kg , Without stand - width: 50.43 cm - depth: 7.76 cm - height: 30.19 cm - weight: 3.05 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80%
