The SA300 monitor equipped with Samsung's unique color engine and White LED-backlight (WLED), features high color accuracy, color temperature and brightness, and also fast response time.
The SA300 monitor delivers images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking contrast ratio, the SA300 monitor ensures that blacks are at their absolute darkest and colors are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. So, take your viewing pleasure to amazing levels of color, brilliance and picture quality with Samsung mega dynamic contrast ratio - and enjoy your multimedia content with the professionalism it deserves.
Upgrade to the next level with mega dynamic contrast ratio
The SA300 monitor delivers images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking contrast ratio, the SA300 monitor ensures that blacks are at their absolute darkest and colors are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. So, take your viewing pleasure to amazing levels of color, brilliance and picture quality with Samsung mega dynamic contrast ratio - and enjoy your multimedia content with the professionalism it deserves. -
Control brightness, conserve energy
Eco saving adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with three energy saving modes, you can really tailor your monitor use to meet your own personal needs. Samsung's commitment to saving energy is designed to help both you and the environment. Take the effort out of saving energy and take control with eco saving. -
See it your way with wider viewing angles
How do you like to watch movies? Do you like lying down on the couch? Sitting in your favorite chair? Cooking or exercising? Whether you're standing, sitting or lying down, Samsung magic angle makes sure that the movie always takes center stage and that you're always comfortable. This means, thanks to the 5-mode angle management, that whatever angle you watch your Samsung monitor, you will enjoy a full visual experience with amazing picture clarity. So, start seeing your favorite movies and other multimedia in total comfort and without limitations thanks to magic angle.
- Samsung S22A300H - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class B
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.24825 mm
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Voltage
- AC 120/230 V
- 51.2 cm x 19.7 cm x 38.5 cm
- 3 kg
- Plug and Play
- Display Type
- Energy Class
- Class B
- Diagonal Size
- 21.5"
- Native Resolution
- Pixel Pitch
- 0.24825 mm
- Colour Support
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 81 kHz
- Video Bandwidth
- 164 MHz
- Backlight Technology
- LED backlight
- MagicBright, Sync on Green, power off timer, MagicTune, MagicColor, MagicAngle, power on timer, Eco Saving
- 51.2 cm x 19.7 cm x 38.5 cm - with stand
- 3 kg
- VGA , HDMI
- Plug and Play
- Power Supply
- External
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
- Included Software
- Samsung MultiScreen
- Dimensions & Weight Details
- With stand - width: 51.2 cm - depth: 19.7 cm - height: 38.5 cm - weight: 3 kg , Without stand - width: 51.2 cm - depth: 5.3 cm - height: 31.1 cm
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
