The slim bezels flow into a symmetrical polished frame for an expansive, balanced display. As a finishing touch, the monochromatic camera housing surrounds a linear camera system. Oh so beautiful.
Galaxy Pro-grade camera
The triple Rear Camera and Selfie Camera offer innovative camera hardware and software so you can easily shoot a Gallery full of share-worthy content. -
Make nights epic with Nightography
The best things happen after dark. Capture it with the epic tech upgrades to the Pro-grade Camera. The big pixel sensor enlarges pixels to pull in light while the Super Clear Glass dials down lens flare - all to make nighttime photos and videos come out clear as day. -
Video at night
Inspiration doesn't wait for optimal lighting - and now you don't have to, either. The biggest leap in Samsung's video technology, auto framerate matches the fps speed to your surroundings and Super Night Solution clears up the noise in each frame for high-quality, vivid footage whether you're in the sun or under the stars. -
Nightography puts portraits in a new light
Get epic low-light portraits and self-portraits thanks to revolutionary upgrades to the Rear Camera and Selfie Camera. Each captures more light for incredible color and detail - so you can master Portrait mode with the lights down low. -
Blurless, stable videos that stay smooth even as you bust a move
The OIS correction angle has been improved by 58% and works with faster motion sampling to stabilize your shots. And your everyday just got more epic and colorful with Super HDR captures it with 64x more color information, even if the scene is backlit. -
Every detail, now yours to capture
Snap away. You'll always end up with a Gallery of sharp, high-quality photos. And within this high-resolution sensor is Adaptive Pixel, which shifts the pixels to suit the lighting. Enable Detail Enhancer before you snap. It intelligently enhances your shots by adjusting shadows and highlights. -
Object Eraser
Keep the focus where it belongs - on your talent. Manually remove people or objects from the background of your snaps, leaving behind only what you want your followers to see. -
Space Zoom
Zoom in 3x, 30x or anywhere in between - it all delivers sharp detail from a distance. -
Infinity-O Display
Sunlight, meet Galaxy S22's bright display. The stunning 120Hz Infinity-O Display is built with Dynamic AMOLED 2X with Vision Booster technology for high outdoor visibility, keeping the view clear in bright daylight or at night. Now the only glare you'll get is from jealous strangers. -
4nm processor: faster, stronger, for longer
Whether you're vlogging your day, gaming all night or simply scrolling your feed, the 4nm processor makes for an incredibly smooth experience. -
Go out for the night without plugging in
Life doesn't slow down, and taking a break to recharge is a fast track to FOMO. The battery intelligently adapts to how you use your phone, so it lasts way beyond 24 hours. -
A tough act to follow
Worry less as you pick up a fallen phone with Corning Gorilla Glass Victus+ on the screen and back panels. The phone is surrounded by a polished, protective Armor Aluminum frame, and with its IP68 water resistance rating, it can take a splash, too. -
Your privacy is secured
Secure your private data from the second you turn your phone on with Samsung Knox. Knox Vault keeps your biometric information safe, while Secure Folder locks down your private data. And the Permission Usage dashboard lets you see which apps are sharing your data or tracking you, and allows you to grant or deny access on your terms.
- Samsung Galaxy S22 - Enterprise Edition - phantom black - 5G smartphone - 128 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- SM-S901B/DS
- Display
- OLED display - 2340 x 1080 pixels - 6.1" - 425 ppi - (120 Hz) - Infinity-O Dynamic AMOLED 2X - HDR - Corning Gorilla Glass Victus+ (scratch resistant glass)
- Processor
- Samsung Exynos 2200 2.8 GHz (8-core)
- Memory
- RAM 8 GB / 128 GB
- Operating System
- Android 12 with Samsung One UI 4.1
- Main Camera
- 50 Megapixel - wide-angle lens - 3x optical zoom - f/1.8 - focus: automatic
- Second Camera
- 12 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- 10 Megapixel - telephoto lens - f/2.4
- Front Camera
- 10 Megapixel f/2.2 - automatic
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Wi-Fi 6, UWB, Bluetooth
- Security Devices
- Fingerprint reader (under display), face recognition
- Connectors
- USB-C
- Talk Time
- Up to 1980 minutes
- Wireless Charging Standards
- WPC, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
- Protection
- Dustproof, splashproof, water-resistant
- Phantom black
- 70.6 mm x 7.6 mm x 146 mm
- 167 g
- Repairability Index
- 8.2 (out of 10)
- Specific Absorption Rate (SAR)
- 1.21 W/kg (head) , 1.59 W/kg (body) , 2.71 W/kg (limb)
- 2-year warranty
- Product Type
- Smartphone
- SM-S901B/DS
- Form Factor
- Touch
- Protection
- 70.6 mm
- 7.6 mm
- 146 mm
- 167 g
- Body Colour
- Phantom black
- Body Material
- Corning Gorilla Glass Victus+, Armour Aluminium frame
- SAR Value
- 1.59 W/kg (body), 1.21 W/kg (head), 2.71 W/kg (limb)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 12
- User Interface
- Samsung One UI 4.1
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch
Communications
- Data Transmission
- FDD-LTE, TDD-LTE, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n75, n77, n78, n40, n25, n12
- 5G NR Frequency
- FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, SDL DL 1500+, TDD TD 3700, TDD TD 3500, TDD 2300, FDD 1900, n12
- NFC, IEEE 802.11a/b/g/n/ac/ax, Ultra-Wideband (UWB), Bluetooth 5.2
Phone Features
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor
- Security Devices
- Additional Features
- MIMO technology, notification flashlight, Smart Select, Three microphones, Samsung KNOX, Smart View, Samsung DeX support, Bixby Vision, Secure Folder function, TalkBack, Dual Audio, Bixby Routines, Intelligent Performance Enhancer, Samsung Smart Switch, Bixby key, Bluetooth Scalable Codec, Samsung Knox Vault, DisplayPort over USB Type-C
Media Player
- Supported Digital Audio Standards
- WAV, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
- Supported Digital Video Standards
- MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, Dolby Digital sound, amplify ambient sound
- Clock Speed
- 2.8 GHz
- Processor Core Qty
- 8-core
- RAM
- LPDDR5 SDRAM - 8 GB
- Internal Memory Capacity
- 128 GB
- User Memory
- 101 GB
Front Camera
- Sensor Resolution
- 10 Megapixel
- Sensor Size
- 1/3.24"
- Lens Aperture
- F/2.2
- Focus Adjustment
- Automatic
- Field of View (FoV)
- 80 degree(s)
- Pixel Size
- 1.22 µm
- Dual Pixel AF
Main Camera
- Sensor Resolution
- 50 Megapixel
- Sensor Size
- 1/1.56"
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.8
- 85 degree(s)
- Pixel Size
- 1 µm
- Focus Adjustment
- Automatic
- Optical Zoom
- 3x
- Digital Zoom
- 30x
- Self-Timer Delay
- Special Effects
- Super HDR, face retouch, Grid Line, selfie colour tone
- Camera Modes
- Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Super Slow-mo, Flowers, Greenery, Trees, Sky, Beaches, Watersides, Snow, Backlit, Text, Food, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Portrait, Night, Motion Photo, Mountain, Filter mode, Single Take, Pro Video, Portrait video, Director's View, Nightography
- HDR Mode
- Auto HDR mode
- Light Source
- High CRI LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 7680 x 4320 (UHD 8K) at 24fps, Hyperlapse 4K video support at 30 fps, Super Steady 1080p video support at 60 fps
- Blink detection, QR-code scanner, RAW image capture, VDIS (Video Digital Image Stabilisation), Tracking AF, Dual Pixel Autofocus technology, Scene Optimiser, Lens smudge, Flaw detection, Shot suggestions, blur detection, HDR10+ recording, Super steady, backlighting detection, Quick Measure, Zoom-In Mic, HEIF image capture, Space Zoom, Take 33MP still photos while playing 8K video, Super Resolution Zoom up to 30x, Digital zoom up to 12x for video, AR Doodle, HEVC (High Efficiency Video coding) support, Auto framing, Detail Enhancer, UW shape correction, Auto FPS, Adaptive Pixel (12MP 2.0µm), object eraser
Second Camera
- Sensor Resolution
- 12 Megapixel
- Sensor Size
- 1/2.55"
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 120 degree(s)
- Pixel Size
- 1.4 µm
Third Camera
- Sensor Resolution
- 10 Megapixel
- Sensor Size
- 1/3.94"
- Lens Type
- Telephoto lens
- Lens Aperture
- F/2.4
- 36 degree(s)
- Pixel Size
- 1 µm
Display
- OLED display
- Technology
- Diagonal Size
- 6.1"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 425 ppi
- Max Brightness
- 1300 cd/m²
- Colour Depth
- 16.7 million colours
- HDR
- HDR Technology
- HDR10+
- Enhancement Technology
- Vision Booster technology
- Refresh Rate
- 120 Hz
- Contrast Ratio
- 2000000:1
- Protection
- AOD(Always On Display), Video Wallpaper, 100% DCI-P3
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 3700 mAh
- Fast Charging Technology
- Qualcomm Quick Charge 2.0, Adaptive Fast Charging, Samsung Super Fast Charging, Power Delivery 3.0
- Wireless Charging
- Talk Time
- 1980 minutes
- Run Time Details
- Active online usage (LTE): up to 15 hrs , Active online usage (Wi-Fi): up to 17 hrs , Playback (wireless video): up to 19 hrs , Playback (wireless audio): up to 57 hrs , Talk (LTE): up to 1980 min
- VDE, IP68, HAC (Hearing Aid Compatible)
- Included Accessories
- SIM card removal tool, USB-C to USB-C cable
- Limited warranty - 2 years
Sustainability Information
- 8.2 (out of 10)
- Max Depth of Water Resistance
- 1.5 m
