Samsung R730 Core i3-380M 4GB RAM 640GB HDD 17.3" Windows 7 Home Premium 64bit Laptop
Quicklinx: 7BSHWS00 Mfr#: NP-R730-JB09UK
  • Core i3
  • Microsoft Windows 7 Home Premium 64-bit Edition
  • IEEE 802.11n
The Samsung R730
Something as powerful, fashionable and reliable as the Samsung R730 shouldn't be so affordable... But it is. Designed to enhance your unique sense of style with patterns to choose as well as comfortably fit your on-the-go lifestyle with its ergonomic engineering and durable casing, this mobile computer is truly a great all-around value. And the casing, engineered to reduce the risk of scratches and fingerprints, ensures that it keeps its cool, smooth looks.
Designed for great value
As affordable as it is powerful, the ultra-stylish R730 delivers true value, combining cool features with a distinctive design. Its ergonomic capabilities make using the R730 both enjoyable and productive, while the unique crystal S-pattern finish will make sure you always stand out from the crowd. It's exactly what you're looking for - high-end design and high performance innovation, give up you more for less.
Crafted for style and safety
Because a life on the go can often trip you up, the Samsung R730 was crafted to not let you down. In fact, its high quality craftsmanship extends as much to its exterior as to its high performance inner workings. Built to withstand bumps and knocks, the R730 comes with a robust, durable casing designed to keep its contents safe and sound as well as reduce the risk of scratches and fingerprints. And its ergonomic, stylish design makes it as coolly eye-catching as it is reliable.
A picture that's close to perfection
The R730's 16:9 aspect ratio immerses you in games and movies with an accurate representation - so you don't have annoying black bands crowding your picture. You'll watch movies the way they were meant to be seen. And see images that are fine-tuned with the sharpest details and boldest colours on a 17.3" HD + LED display. An added bonus? It uses less power, so you can be entertained longer. Get more out of your on-the-go entertainment and enjoy a bigger, better picture.
Easy-to-use numeric keypad
With an expansive 17-key numeric keypad, hitting the right number key is easier than ever - especially if your fingertips are used to tapping away at your PC. Whether you're using Excel spreadsheets, doing calculations or playing video games, it all adds up: Samsung's numeric keyboard offers easy, enhanced usability.
Get online almost anywhere
The R730 incorporates advanced communications technologies, including 802.11bgn wireless, to provide high-speed access to the Internet and your data anytime and anywhere.
  • Designed for great value
    As affordable as it is powerful, the ultra-stylish R730 delivers true value, combining cool features with a distinctive design. Its ergonomic capabilities make using the R730 both enjoyable and productive. It's exactly what you're looking for - high-end design and high performance; give up you more for less.
  • Crafted for style and safety
  • Get online almost anywhere
    The R730 incorporates advanced communications technologies, including 802.11 b/g/n wireless, to provide high-speed access to the Internet and your data anytime and anywhere.
  • Easy-to-use numeric keypad
  • A picture that's close to perfection
    The R730's 16:9 aspect ratio immerses you in games and movies with an accurate representation - so you don't have annoying black bands crowding your picture. You'll watch movies the way they were meant to be seen. And see images that are fine-tuned with the sharpest details and boldest colors on a 17.3" HD + LED display. It uses less power, so you can be entertained longer. Get more out of your on-the-go entertainment and enjoy a bigger, better picture.
Samsung R730 JB09 - 17.3" - Intel Core i3 - 380M - 4 GB RAM - 640 GB HDD
Notebook
Operating System
Win 7 Home Premium 64-bit
Intel Core i3 380M / 2.53 GHz / 3 MB Cache
4 GB DDR3 (2 x 2 GB)
Storage
640 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
17.3" LED backlight 1600 x 900 / HD+
Graphics
Intel HD Graphics
Numeric Keypad
Integrated Webcam
802.11b/g/n, 10/100 Ethernet
6-cell
41.1 cm x 27.3 cm x 4 cm
2.8 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Chipset
Mobile Intel HM55 Express
Hyper-Threading Technology, Intel Virtualization Technology, Intel 64 Technology
RAM
4 GB (2 x 2 GB)
DDR3 SDRAM
Speed
1066 MHz
Slots Qty
2
Empty Slots
0
Storage
Main Storage
640 GB HDD SATA 1.5Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM fixed
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 2.4x (DVD+R DL)
CD / DVD Rewrite Speed
16x (CD) / 4x (DVD±RW) / 5x (DVD-RAM)
Display
17.3"
LCD Backlight Technology
LED backlight
Resolution
1600 x 900 (HD+)
Widescreen
Super Bright Gloss
Audio & Video
Graphics Processor
Intel HD Graphics
Memory Allocation Technology
Dynamic Video Memory Technology 5.0
Camera
Sound
Stereo speakers, microphone
High Definition Audio, SRS 3D Sound
Input
Keyboard, touchpad
Numeric Keypad
Scrolling, Flat, multi-gesture touch pad
Communications
Wireless
802.11b/g/n
Network Interface
10/100 Ethernet
6-cell Lithium Ion
4400 mAh
AC Adapter
Output
60 Watt
Connections & Expansion
Interfaces Details
VGA , Headphone output , Microphone input , 3 x USB 2.0 , LAN , HDMI
Memory Card Reader
3 in 1 (SD Card, MultiMediaCard, SDHC Card)
Software
Software Included
Adobe Acrobat Reader, McAfee VirusScan (Trial), Samsung Update Plus, SAMSUNG Support Center, CyberLink DVD Suite, Samsung Recovery Solution, Samsung Easy Battery Manager, Samsung Easy Network Manager, Samsung Easy Display Manager, Samsung Easy Speed Up Manager
Security lock slot (cable lock sold separately), system password, hard drive password
Localization
2.8 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
