Samsung R540 Pentium Dual Core P6100 4GB RAM 500GB HDD 15.6" Windows 7 Home Premium Laptop
Quicklinx: 7C07WS00 Mfr#: NP-R540-JA07UK
  • Pentium
  • Microsoft Windows 7 Home Premium 64-bit Edition
  • IEEE 802.11n
The R540 notebook delivers powerful performance in a gorgeous design, without having to pay a pretty penny. With a glass-like platinum finish, the R540 gives you style and performance, all in one laptop.
The R540's 15.6" LED-backlit LCD HD display produces bright, colorful HD images and is combined with SRS premium sound for impressive gaming and multimedia. With a 16:9 aspect ratio, you can watch true HD movies in 16:9 widescreen format that fits the full size of the screen, without any black bands. You'll see images that are fine-tuned with the sharpest details and boldest color.
  • Stylish design
  • Vibrant LED-backlit HD display
  • Keeps you connected
    The R540 has a host of advanced connectivity tools, including a 3-in-1 card slot, 3 x USB 2.0 ports and PC-to-PC connectivity for real-time sharing. With a low-light webcam you can make videoconferencing possible from virtually anywhere. Move data easily from your digital camera, camcorder, MP3 player or PDA straight to the laptop.
  • Full sized isolation keyboard
    Keeping you comfortable and productive when typing, the R540 features a full-size isolation-type keyboard with integrated 17-key numeric pad. And with a weight of just 5.29 pounds, and long battery life, the R540 is the very definition of go-anywhere, do-anything computing. Battery life will vary depending on the product model, configuration, power management settings, and applications used and wireless settings. The maximum capacity of the battery will decrease with time and use.
Samsung R540 JA07 - 15.6" - Pentium P6100 - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 7 Home Premium 64-bit
Intel Pentium P6100 / 2 GHz / 3 MB Cache
4 GB DDR3 (2 x 2 GB)
Storage
500 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Integrated Webcam
802.11b/g/n, 10/100 Ethernet
6-cell
38 cm x 25.6 cm x 3.8 cm
2.4 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - 1 year - pick-up and return , International warranty - 1 year
Notebook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Chipset
Mobile Intel GL40 Express
RAM
4 GB (2 x 2 GB)
Max RAM Supported
8 GB
DDR3 SDRAM
Speed
1066 MHz / PC3-8500
Rated Speed
1066 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM fixed
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Super Bright Gloss
Audio & Video
Camera
Sound
Stereo speakers, microphone
High Definition Audio, SRS 3D Sound
Input
Keyboard, touchpad
Communications
Wireless
802.11b/g/n
Network Interface
10/100 Ethernet
6-cell
AC Adapter
Input
AC 120/230 V
Output
60 Watt
Connections & Expansion
VGA , Headphone output , Microphone input , 3 x USB 2.0 , LAN , HDMI
Memory Card Reader
3 in 1 (SD Card, MultiMediaCard, SDHC Card)
Software
Software Included
Samsung Update Plus, Samsung Battery Life Extender, SAMSUNG Support Center, Samsung Recovery Solution, Samsung Easy Network Manager, Samsung Easy Display Manager, Samsung Easy Speed Up Manager, CyberLink Youcam, McAfee Internet Security Suite (60 days trial), Samsung Easy Content Share, Samsung Easy File Share
Security lock slot (cable lock sold separately), system password, hard drive password, SuperSilent Mode
Localization
2.4 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
