Samsung QM85R-B 85" 3840x2160 8ms HDMI USB LED-backlit LCD Display
Quicklinx: GSPKWS00 Mfr#: LH85QMRBBGCXEN
Samsung's QMR-B series displays cut through the clutter to deliver best-in-class UHD resolution as well as intelligent UHD upscaling and rich flawless colors with Dynamic Crystal Color all in a slim design.
Samsung QM85R-B QMR-B Series - 85" Class (84.5" viewable) LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
85"
Diagonal Size
84.5"
Commercial Use
Yes - digital signage
Platform
Tizen OS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN
PC Interface
DisplayPort
S-PVA
LCD Backlight Technology
Edge LED BLU
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SMART Signage Platform, Auto Source Switching & Recovery, hot key option, LFD Home UI, MagicInfo S6 Player, MagicInfo Express 2
Picture Enhancements
Noise Reduction, Dynamic Crystal Color, Intelligent UHD upscaling, Dynamic Crystal Display, Edge Restoration, 92% Colour Gamut (DCI-P3, CIE 1976)
Speaker System
2 channel
Storage Capacity
8 GB (system 3.88 GB + available 4.12 GB)
USB
2 ports
Remote control
Power Consumption Stand by
0.5 Watt
189.78 cm x 5.67 cm x 108.08 cm
48.4 kg
3-year warranty
Power Consumption (Max)
217 Watt
217 kWh/1000h
Diagonal Class
85"
Diagonal Size
84.5"
Commercial Use
Series
QMR-B Series
Platform
Tizen OS
Operating System
Tizen OS 4.0
Video Processor
Crystal 4K
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DisplayPort
Design
Elegant
Protection
Dustproof
Dimensions
Without stand
189.78 cm
5.67 cm
108.08 cm
48.4 kg
Enclosure Colour
Display
LCD Display Technology
S-PVA
Colour Support
16700000 colours
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Edge LED BLU
Coating
Anti-glare, 28% haze
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Operation Hours / Days
24 / 7
Pivot, key lock, SSSP 6.0
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
VESA Compatibility
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, AVC, H.264, H.263, VC-1, HEVC, MPEG, VP9, VP8, AVS+
Supported Audio Formats
AC3
Supported Pictures Formats
PNG, JPEG
USB Port
USB Ports Qty
2
Configuration
ARM Cortex-A72 Quad-Core ( 1.7 GHz ) - 2.5 GB LPDDR4 - 8 GB (system 3.88 GB + available 4.12 GB)
Remote Control
Remote control
Battery Included
Audio System
Speaker System
2 channel
External Speakers Amplifier Power (Total)
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
Wi-Fi, LAN
Wi-Fi Protocol
802.11n
Connect & Share
Screen Mirroring, Wi-Fi Miracast
Connector Type
2 x HDMI input , DisplayPort input , 2 x USB 2.0 , Audio line-in , Audio line-out , RS-232 input , RS-232 output , LAN , Infrared input
Plug and Play, EMC Class B, IP5X, HDCP 2.2, IEC/EN 62368-1
Power supply
0.5 Watt
Limited warranty - 3 years
Width (Shipping)
209 cm
Depth (Shipping)
26 cm
Height (Shipping)
124.7 cm
Weight (Shipping)
63.7 kg
10 - 80%
