Slim, symmetrical design that will stand the test of time and ensure the QMR-B series blends seamlessly into any environment, with simple installation to get your display up and running as soon as possible.
- Samsung QM32R-B QMR-B Series - 32" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 32"
- Commercial Use
- Yes - digital signage
- Platform
- Tizen OS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- DisplayPort
- Technology
- VA
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- SMART Signage Platform
- Picture Enhancements
- Mega Dynamic Contrast Ratio, 72% Colour Gamut
- Storage Capacity
- 8 GB
- USB
- 2 ports
- Voltage
- AC 100-240 V (50/60 Hz)
- 72 watt
- Dimensions (WxDxH) - without stand
- 72.51 cm x 3.46 cm x 41.96 cm
- 5.7 kg
- 3-year warranty
- Product Type
- 72 watt
- Diagonal Class
- 32"
- Commercial Use
- Series
- QMR-B Series
- Platform
- Tizen OS
- Operating System
- Tizen OS 4.0
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Infrared (IR)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DisplayPort
- Design
- Slim Design
- Dimensions
- Without stand
- 72.51 cm
- 3.46 cm
- 41.96 cm
- 5.7 kg
Display
- LCD Display Technology
- VA
- Pixel Pitch
- 0.36375 mm
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- 2% haze
- Image Contrast Ratio
- 5000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Pivot, SSSP, clean cable management, Samsung Workspace secured by Knox
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 200 x 200 mm
- VESA Compatibility
Media Player
- USB Port
- USB Ports Qty
- 2
- Configuration
- 8 GB
Network & Internet Multimedia
- Connectivity
- Wi-Fi, LAN
- Connector Type
- 2 x HDMI input , DisplayPort input , 2 x USB 2.0 , Audio line-in , Audio line-out , RS-232 input , RS-232 output , LAN
- EMC Class B, HDCP 2.2, Safety 60950-1, Safety 62368-1
- Power Device
- Power supply
- Input Voltage
- Power Consumption Sleep
- 0.5 watt
- Limited warranty - 3 years
- Width (Shipping)
- 81.2 cm
- Depth (Shipping)
- 12 cm
- Height (Shipping)
- 51.3 cm
- Weight (Shipping)
- 8 kg
- 0 °C
- 40 °C
- 10 - 80%
