Samsung QM-F Series 98" Edge-Lit 4K UHD LED Display
Quicklinx: D2HCWS00 Mfr#: LH98QMFPLGC/EN
Samsung QMF Series SMART Signage delivers 3,840 x 2,160 resolution, multi-format PIP support, DP 1.2 support, set-back box (SBB) support, portrait or landscape orientation and reliable 24/7 operation for amazing flexibility in commercial settings. The UHD displays deliver a super-crisp image with high pixel density that is perfect for displaying even the smallest details of photos and videos in a hyper-realistic and immersive visual experience. Non-glare panels come as standard to ensure outstanding performance in bright conditions. Boasting a narrow bezel configuration, the standalone displays offer a compact solution to environments limited by space or lighting. The UHD line-up is designed to deliver superior image quality in all environments. The versatile range of displays is specially configured to suit any business application. For example, retail stores can leverage Samsung QMF Series with UHD to improve their brand image and showcase products in sharp detail, while corporations and arena or museum security centers can use the high-resolution displays to enhance security with stable and vivid content playback.
  • Attract customers and improve brand identity with UHD lifelike images and picture quality
    QMF Series delivers four times the FHD resolution on the same screen area, resulting in the most accurate recreation of details possible. Text that displays on QMF Series in UHD is super-crisp due to its high pixel density. High-detail visuals, such as photos and videos, are visible with the smallest details for a hyper-realistic and immersive visual experience. In addition, customers can replace older video walls composed of smaller FHD displays with a single large QMF Series display to eliminate the bezels and produce a seamless view of the content. The resolution made up of the four FHD displays is singlehandedly covered by one UHD display.
  • Display four times the FHD content on a single multiscreen for greater visual impact
    UHD offers four times the resolution of FHD, which means that you can display the equivalent of four FHD content screens on a single UHD screen. Various PIP and split-screen scenarios are possible, far beyond just four equally separated rectangles. This flexibility enables dynamic and efficient usage scenarios, such as the display of a video conferencing system on a large part of the screen, along with reference documents from a different device on another screen area for meeting attendees, or a product image display next to a specifications list in a retail store.
  • Choose the optimal display orientation with pivot mode
    To meet the demands of traditional commercial environments, digital signage is often installed in portrait mode. Thus, it is critical that the digital signage supports portrait installation to fit to the aesthetics of the setting while still delivering the dynamic qualities of digital signage. QMF Series offers pivot mode that allows them to be installed in either landscape or portrait orientation to suit the environment’s needs.
  • Enjoy seamless video playback with QMF support for DP 1.2
    QMF Series natively supports a high 60 Hz refresh rate that ensures seamless video playback and eliminates the choppy visual experience often observed at a lower refresh rate. The QMF Series supports DP 1.2 connectivity, which is capable of streaming UHD video content at a refresh rate of 60 Hz, delivering a true UHD experience.
Samsung QM98F QM-F Series - 98" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
98"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
4 ports
LAN
PC Interface
DVI, DisplayPort
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Auto Source Switching & Recovery
Picture Enhancements
Mega Dynamic Contrast Ratio
Speaker System
2 speakers
Remote control, batteries
Voltage
Energy Class
Class B
Power Consumption (On mode)
476 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
695 kWh
219.42 cm x 7.13 cm x 124.98 cm
80 kg
Energy Class
Class B
476 W
695 kWh
Diagonal Class
98"
Commercial Use
Series
QM-F Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
DVI, DisplayPort
Dimensions
Without stand
219.42 cm
7.13 cm
124.98 cm
80 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Edge-lit LED
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), picture by picture (no tuner)
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
900 x 600 mm
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
DVI-I input , 2 x DisplayPort input , 4 x HDMI input , Service , Audio line-in , Audio line-out , Serial input , Serial output , LAN , Infrared input , Infrared output
Batteries
Plug and Play, EMC Class A, cUL No.60950-1
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Width (Shipping)
245.5 cm
Depth (Shipping)
60.5 cm
Height (Shipping)
148.3 cm
Weight (Shipping)
140.6 kg
10 - 80%
