Samsung QMF SMART Signage delivers 3,840 x 2,160 resolution, multi-format PIP support, DP 1.2 support, set-back box (SBB) support, portrait or landscape orientation and reliable 24/7 operation for amazing flexibility in commercial settings.
The UHD display delivers a super-crisp image with high pixel density that is perfect for displaying even the smallest details of photos and videos in a hyper-realistic and immersive visual experience. Non-glare panels come as standard to ensure outstanding performance in bright conditions.
Boasting a narrow-bezel configuration, the standalone displays offer a compact solution to environments limited by space or lighting. It is designed to deliver superior image quality in all environments.
Attract customers and improve brand identity with UHD lifelike images and picture quality
QMF delivers four times the FHD resolution on the same screen area, resulting in the most accurate recreation of details possible. Text that displays on QMF in UHD is super-crisp due to its high pixel density. High-detail visuals, such as photos and videos, are visible with the smallest details for a hyper-realistic and immersive visual experience. In addition, customers can replace older video walls composed of smaller FHD displays with a single large QMF display to eliminate the bezels and produce a seamless view of the content. The resolution made up of the four FHD displays is singlehandedly covered by one UHD display. -
Display four times the FHD content on a single multiscreen for greater visual impact
Provide more information through a smaller number of displays. UHD offers four times the resolution of FHD, which means that you can display the equivalent of four FHD content screens on a single UHD screen. QMF features a wide array of connectivity options, including the ability to display content from four separate input devices on the same screen without the need to first merge the content on a separate PC. With QMF, no special third-party components are required. Various PIP and split-screen scenarios are possible, far beyond just four equally separated rectangles. This flexibility enables dynamic and efficient usage scenarios, such as the display of a video conferencing system on a large part of the screen, along with reference documents from a different device on another screen area for meeting attendees, or a product image display next to a specifications list in a retail store. -
Choose the optimal display orientation with pivot mode
To meet the demands of traditional commercial environments, digital signage is often installed in portrait mode. Thus, it is critical that the digital signage supports portrait installation to fit to the aesthetics of the setting while still delivering the dynamic qualities of digital signage. QMF offers pivot mode that allows it to be installed in either landscape or portrait orientation to suit the environment's needs. -
Enjoy seamless video playback with QMF support for DP 1.2
QMF natively supports a high 60 Hz refresh rate that ensures seamless video playback and eliminates the choppy visual experience often observed at a lower refresh rate. The QMF supports DP 1.2 connectivity, which is capable of streaming UHD video content at a refresh rate of 60 Hz, delivering a true UHD experience.
- Samsung QM75F QM-F Series - 75" LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 75"
- Commercial Use
- Yes - digital signage
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- LAN
- PC Interface
- DVI, DisplayPort
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- Power Consumption (On mode)
- 277 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 404 kWh
- Dimensions (WxDxH) - without stand
- 168.14 cm x 6.21 cm x 96.12 cm
- Product Type
- Energy Class
- Class B
- 277 W
- 404 kWh
- Diagonal Class
- 75"
- Commercial Use
- Series
- QM-F Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- PC Interface
- DVI, DisplayPort
- Dimensions
- Without stand
- 168.14 cm
- 6.21 cm
- 96.12 cm
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Edge-lit LED
- Coating
- Anti-reflection
- Image Contrast Ratio
- 4700:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Operation Hours / Days
- 24 / 7
- Pivot
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- DVI-I input , 2 x DisplayPort input , 4 x HDMI input , USB , Audio line-in , Audio line-out , Serial input , Serial output , LAN
- Batteries
- IP5X
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- 0 °C
- 40 °C
- 10 - 80%
