Samsung QM-F Series 49" Edge-Lit 4K UHD LED Display
Quicklinx: D2H5WS00 Mfr#: LH49QMFPLGC/EN
Today's businesses, including banks, restaurants, retailers and more, are increasingly using digital signage to engage, educate and serve their customers. Commercial digital signage usage continues to increase, and, because of its ability to offer clearer text and images, UHD has become the next big thing in display technology. With the UHD technology, businesses can leverage the next generation of ultimate picture quality for conveying more impactful messaging and information. UHD offers ultra-realistic detail, the ability to display more information on one screen, and four times the detail clarity, which is most evident when displaying text. For commercial applications, essential features, such as portrait mode and longer operational hours, are combined with UHD clarity for the ultimate commercial display.
  • Bring the next generation of UHD picture quality to your commercial environment
  • UHD display QMF which designed for a commercial environment
    The UHD line-up is designed to deliver superior image quality in all environments. The versatile range of displays is specially configured to suit any business application. The UHD displays deliver a super-crisp image with high pixel density that is perfect for displaying even the smallest details of photos and videos in a hyper-realistic and immersive visual experience. Non-glare panels come as standard to ensure outstanding performance in bright conditions. Boasting a narrow-bezel configuration, the standalone displays offer a compact solution to environments limited by space or lighting. The unique bezel design helps drive clear, uninterrupted viewing.
  • Attract customers and improve brand identity with UHD lifelike images and picture quality
    QMF Series delivers four times the FHD resolution on the same screen area, resulting in accurate recreation of details. Text that displays on QMF Series in UHD is super-crisp due to its high pixel density. High-detail visuals, such as photos and videos, are visible with the smallest details for a hyper-realistic and immersive visual experience.
  • Display four times the FHD content on a single multiscreen for greater visual impact
    You can provide more information through a smaller number of displays. UHD offers four times the resolution of FHD, which means that you can display the equivalent of four FHD content screens on a single UHD screen. QMF Series features a wide array of connectivity options, including the ability to display content from four separate input devices on the same screen without the need to first merge the content on a separate PC. With QMF Series, no special third-party components are required.
Samsung QM49F QM-F Series - 49" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
49"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
4 ports
LAN
PC Interface
DVI, DisplayPort
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Auto Source Switching & Recovery
Speaker System
2 speakers
Remote control, batteries
Voltage
Energy Class
Class B
154 watt
Power Consumption (On mode)
100 W
Power Consumption Stand by
0.5 watt
Energy Consumption per Year
146 kWh
109.94 cm x 3.68 cm x 63.4 cm
13.6 kg
Energy Class
Class B
154 watt
100 W
146 kWh
Diagonal Class
49"
Commercial Use
Series
QM-F Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
DVI, DisplayPort
Dimensions
Without stand
109.94 cm
3.68 cm
63.4 cm
13.6 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Edge-lit LED
Coating
Anti-glare
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, d-LED BLU, Mega Dynamic Contrast Ratio, SBB (attachable)
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 watt
Speakers
2 x main channel speaker - 10 watt
Network & Internet Multimedia
LAN
Connector Type
DVI-I input , 2 x DisplayPort input , 4 x HDMI input , Service , Audio line-in , Audio line-out , Serial input , Serial output , LAN , Infrared input , Infrared output
Batteries
Plug and Play, EMC, IP5X
Power supply
Input Voltage
0.5 watt
Power Consumption (Off Mode)
0 watt
Width (Shipping)
119.5 cm
Depth (Shipping)
17.7 cm
Height (Shipping)
72.1 cm
Weight (Shipping)
18.4 kg
10 - 80%
