Samsung's QET series features intelligent upscaling technology that displays all content in eye-catching UHD resolution along with a boundless design and simple content management features.
- Samsung QE75T QET Series - 75" LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 75"
- Commercial Use
- Yes - digital signage
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- SMART Signage Platform
- Picture Enhancements
- Mega Dynamic Contrast Ratio, 72% Colour Gamut
- USB
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 253 watt
- Power Consumption (On mode)
- 171 W
- Power Consumption Stand by
- 0.5 watt
- Energy Consumption per Year
- 250 kWh
- Dimensions (WxDxH) - without stand
- 167.32 cm x 5.99 cm x 95.82 cm
- 30.9 kg
- Product Type
- Energy Class
- Class A
- 253 watt
- 171 W
- 250 kWh
- Diagonal Class
- 75"
- Commercial Use
- Series
- QET Series
- Video Processor
- Crystal 4K
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Design
- 3-sided frameless design
- Dimensions
- Without stand
- 167.32 cm
- 5.99 cm
- 95.82 cm
- 30.9 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 1200:1
- Brightness
- 300 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Operation Hours / Days
- 16 / 7
- MagicInfo Lite
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
- VESA Compatibility
Media Player
- USB Port
- USB Ports Qty
- 1
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- 2 x HDMI input , USB , Audio line-out , RS-232C input , LAN
- UL, VCCI, C-Tick, BSMI, GOST, NOM, SASO, UL 60950, CB, AS/NZS 60950-1, CCC, PSB, IRAM, RoHS, IEC 60950-1, EN 60950-1, NOM-019-SCFI-1998, K60950-1, EAC, RCM, CNS 14336, IS13252, GB 17625.1-2012, BIS, INMETRO, FCC Part 15 Class B, GB 4943.1-2011, KN32, KN35, KCC/EK, VCCI-CISPR 32:2016, IEC 60065-1, AS/NZS CISPR 32:2015, GB/T9254-2008, CNS 13438 ITE EMI, ROCT CISPR 24-2013, ROCT CISPR 22:2005, CNS 15663
- Power Device
- Power supply
- Input Voltage
- 0.5 watt
- Width (Shipping)
- 184 cm
- Depth (Shipping)
- 19.8 cm
- Height (Shipping)
- 111.8 cm
- Weight (Shipping)
- 41.5 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
