Samsung's QET series features intelligent upscaling technology that displays all content in eye-catching UHD resolution along with a boundless design and simple content management features.
- Samsung QE65T QET Series - 65" LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/360445
- Diagonal Class
- 65"
- Commercial Use
- Yes - digital signage
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- SMART Signage Platform
- Picture Enhancements
- Mega Dynamic Contrast Ratio, Noise Reduction, Intelligent UHD upscaling, 72% Colour Gamut, Crystal Display, Edge Restoration
- USB
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class G
- 204 watt
- Power Consumption (On mode)
- 145 W
- Power Consumption Stand by
- 0.5 watt
- Energy Consumption per Year
- 212 kWh
- Dimensions (WxDxH) - without stand
- 144.94 cm x 5.99 cm x 83.03 cm
- 21.2 kg
- Product Type
- Energy Class
- Class G
- 204 watt
- 145 W
- Power Consumption SDR (On mode)
- 145 kWh/1000h
- 212 kWh
- Diagonal Class
- 65"
- Commercial Use
- Series
- QET Series
- Video Processor
- Crystal 4K
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Design
- 3 Bezel-less Design
- Dimensions
- Without stand
- 144.94 cm
- 5.99 cm
- 83.03 cm
- 21.2 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Coating
- 2% haze
- Image Contrast Ratio
- 4000:1
- Brightness
- 300 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- MagicInfo Lite
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 300 mm
- VESA Compatibility
Media Player
- USB Port
- USB Ports Qty
- 1
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- 2 x HDMI input , USB , Audio line-out , RS-232C input , Remote control
- UL, C-Tick, GOST, NOM, SASO, CB, AS/NZS 60950-1, CCC, EMC, PSB, IRAM, KCC, BSMI CNS 13438, KC, NOM-019-SCFI-1998, K60950-1, RCM, IS13252, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO, GB4943.1-2001, EN 55024:2010, FCC Part 15 Class B, KN32, EN 55032:2012, CNS 14336-1, IEC/EN 60950-1, KCC KN35, VCCI-CISPR 32:2016, AS/NZS CISPR 32:2015, RoHS CNS 15663, EN 55035:2017, GB/T9254-2008, ROCT CISPR 24-2013, ROCT CISPR 22:2005
- Power Device
- Power supply
- Input Voltage
- 0.5 watt
- Width (Shipping)
- 160.6 cm
- Depth (Shipping)
- 18.4 cm
- Height (Shipping)
- 96.3 cm
- Weight (Shipping)
- 29.4 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
