As visual display technology evolves, viewers develop heightened expectations about picture quality. As Ultra HD resolution continues to grow in popularity, it is essential for businesses to deliver superb picture quality for their customers. While much content is still being produced at a lower resolution, Intelligent Ultra HD upscaling technology helps Samsung's 4K Ultra HD signage increase low resolution content to Ultra HD picture quality.
Ultra HD 4K resolution
Samsung's QBR series is able to hook customer attention by providing an incredibly clear picture, showcasing lifelike images and intricate details better than ever before thanks to ultra-high definition 4K resolution. -
Samsung has developed its powerful video processor for use in its digital signage. Additionally, intelligent Ultra HD upscaling technology is an advanced solution based on Samsung's proprietary intelligent Ultra HD engine that allows content developed at a lower resolution to be elevated to Ultra HD-level quality. It also performs edge restoration and noise reduction to optimize on-screen text and imagery with crisp edges and fine detail. -
Dynamic Crystal Color
Dynamic Crystal Color is what brings the incredible, lifelike color to Samsung displays. Using 10-bit processing, the display is able to showcase a wider spectrum of colors - up to a billion different shades - capturing subtle differences for flawless color expression, critical for businesses in ensuring brand consistency across communication channels. Samsung 4K Signage QBR series also features HDR10+ functionality that converts standard definition (SDR) content to HDR quality for sharper contrast and more vivid colors. -
Slim and symmetrical design
The slim and symmetrical design of the QBR series vastly simplifies wall mounting the display and ensures that installation is a seamless process. The display's power inlet direction has been redesigned to perfectly align against the wall. -
Clean cable management
With QBR's cable guide feature, retailers are able to tuck away messy cables from view. This allows for a clean and visually-appealing shopping experience for customers, even when the back of the display is visible. -
Wi-Fi and Bluetooth built-in
Built-in Wi-Fi and Bluetooth allow for more personalized and interactive services as well as simplifying how businesses showcase content. Whether it's to make networking simpler or enabling interactive beacon technology in-store, QBR series displays help businesses move into the future of retail.
- Samsung QB43R QBR Series - 43" LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 43"
- Commercial Use
- Yes - digital signage
- Black
- Platform
- Tizen OS 4.0
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- HDR Format
- HDR10+
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- PC Interface
- DVI
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- SMART Signage Platform
- Picture Enhancements
- Mega Dynamic Contrast Ratio, UHD Upscaling, Dynamic Crystal Color
- USB
- 2 ports
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class G
- 110 Watt
- Power Consumption (On mode)
- 67 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 98 kWh
- Dimensions (WxDxH) - without stand
- 96.75 cm x 4.83 cm x 55.77 cm
- 10 kg
- Product Type
- Energy Class
- Class G
- 110 Watt
- 67 W
- Power Consumption SDR (On mode)
- 67 kWh/1000h
- 98 kWh
- Diagonal Class
- 43"
- Commercial Use
- Series
- QBR Series
- Platform
- Tizen OS 4.0
- HDR Capable
- HDR Format
- HDR10+
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI
- Design
- Narrow Bezel Design, Slim Design, New Edge Design
- Dimensions
- Without stand
- 96.75 cm
- 4.83 cm
- 55.77 cm
- 10 kg
- Enclosure Colour
- Black
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Coating
- 0.02% Glass Haze
- Image Contrast Ratio
- 4000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 200 x 200 mm
- VESA Compatibility
Media Player
- USB Port
- USB Ports Qty
- 2
Network & Internet Multimedia
- Connectivity
- Connector Type
- 2 x HDMI input , DVI-Digital , 2 x USB , Audio line-in , Infrared input , Audio line-out , RS-232 input , RS-232 output , LAN
- UL, VCCI, C-Tick, BSMI, GOST, cUL, NOM, SASO, CB, FCC Part 15 B, AS/NZS 60950-1, CCC, EMC, PSB, IRAM, EN 60950-1, KC, AS/NZS, NOM-019-SCFI-1998, K60950-1, EAC, NOM-001-SCFI-1993 IRAM, RCM, IS13252, GB 17625.1-2012, BIS, INMETRO, IEC60950-1, GB 4943.1-2011, KN32, KN35, KCC/EK, CNS 14336-1, CISPR 32:2015, RoHS CNS 15663, CISPR 32:2016, GB/T9254-2008, CNS 13438 ITE EMI, ROCT CISPR 24-2013, ROCT CISPR 22:2005
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 109.5 cm
- Depth (Shipping)
- 15.1 cm
- Height (Shipping)
- 67.6 cm
- Weight (Shipping)
- 13.3 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
