Samsung QB13R-T 13 INCH UHD Entry Level Touch LFD 16/7 usage 250nit
Quicklinx: HBB9WS00 Mfr#: LH13QBRTBGCXEN
Hurry, only 1 left in stock!
£524.94 ex VAT
£629.92 inc VAT
The Samsung QB13R-T commercial display is a versatile solution designed to meet the demands of digital signage and interactive communication. With a 13-inch Full HD 1080p display that features LED backlight technology and an anti-glare coating, it ensures vivid image clarity and visibility in various lighting conditions. The display supports up to 10 touchpoints, offering an engaging user experience for interactive applications.
This model is equipped with multiple connectivity options, including HDMI, USB, LAN, and Wi-Fi, facilitating easy integration into existing systems. It is built to operate for 16 hours a day, making it an ideal choice for a wide range of commercial settings. Additionally, the Samsung QB13R-T is designed to withstand the rigors of daily use, complying with EMC Class B and IP5X standards, ensuring reliability and durability. With its energy-efficient design, consuming only 27.5 W during operation and 0.5 W in sleep mode, it offers an economical solution for businesses looking to enhance their digital communication.
Samsung QB13R-T QBR Series - 13" LED display unit - Full HD - for digital signage / interactive communication
LED display unit with touchscreen (multi touch)
Diagonal Class
13"
Commercial Use
Yes - interactive digital signage
Platform
Tizen OS
Resolution
1920 x 1080
Display Format
1080p
Video Interface
HDMI
HDMI Ports Qty
1 ports
Wi-Fi, LAN
ADS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
MagicInfo S Player
USB
2 ports
Voltage
Energy Class
Class B
27.5 Watt
Power Consumption (On mode)
14 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
20 kWh
32.2 cm x 2.98 cm x 19.35 cm
1.1 kg
LED display unit
Energy Class
Class B
27.5 Watt
14 W
20 kWh
Diagonal Class
13"
Commercial Use
Combined With
Touchscreen (multi touch)
Series
QBR Series
Platform
Tizen OS
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
1 ports
Dimensions
Without stand
32.2 cm
2.98 cm
19.35 cm
1.1 kg
Display
LCD Display Technology
ADS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Image Contrast Ratio
600:1
Dynamic Contrast Ratio
10000:1
Brightness
250 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
10
Response Time
8 ms
Commercial Features
MagicInfo S Player
Operation Hours / Days
16 / 7
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm
VESA Compatibility
Media Player
USB Port
USB Ports Qty
2
Network & Internet Multimedia
Wi-Fi, LAN
Connector Type
HDMI input , 2 x USB , Audio line-out , RS-232 input , LAN
UL, VCCI, C-Tick, BSMI, NOM, SASO, CB, AS/NZS 60950-1, CCC, EMC, PSB, IRAM, IEC 60950-1, EN 60950-1, KCC, KC, EMC Class B, NOM-019-SCFI-1998, K60950-1, EAC, NOM-001-SCFI-1993 IRAM, RCM, IP5X, IS13252, GB 17625.1-2012, INMETRO, FCC Part 15 Class B, GB 4943.1-2011, KN32, KN35, CNS 14336-1, VCCI-CISPR 32:2016, AS/NZS CISPR 32:2015, RoHS CNS 15663, GB/T9254-2008, CNS 13438 ITE EMI, ROCT CISPR 24-2013, ROCT CISPR 22:2005
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
37.6 cm
Depth (Shipping)
24.8 cm
Height (Shipping)
13.2 cm
Weight (Shipping)
2 kg
10 - 80% (non-condensing)
Brand: Samsung
Price Range Ex VAT: £500 - £750
