The Samsung QB13R-T commercial display is a versatile solution designed to meet the demands of digital signage and interactive communication. With a 13-inch Full HD 1080p display that features LED backlight technology and an anti-glare coating, it ensures vivid image clarity and visibility in various lighting conditions. The display supports up to 10 touchpoints, offering an engaging user experience for interactive applications.
This model is equipped with multiple connectivity options, including HDMI, USB, LAN, and Wi-Fi, facilitating easy integration into existing systems. It is built to operate for 16 hours a day, making it an ideal choice for a wide range of commercial settings. Additionally, the Samsung QB13R-T is designed to withstand the rigors of daily use, complying with EMC Class B and IP5X standards, ensuring reliability and durability. With its energy-efficient design, consuming only 27.5 W during operation and 0.5 W in sleep mode, it offers an economical solution for businesses looking to enhance their digital communication.
- Samsung QB13R-T QBR Series - 13" LED display unit - Full HD - for digital signage / interactive communication
- Product Type
- LED display unit with touchscreen (multi touch)
- Diagonal Class
- 13"
- Commercial Use
- Yes - interactive digital signage
- Platform
- Tizen OS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- Wi-Fi, LAN
- Technology
- ADS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- MagicInfo S Player
- USB
- 2 ports
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 27.5 Watt
- Power Consumption (On mode)
- 14 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 20 kWh
- Dimensions (WxDxH) - without stand
- 32.2 cm x 2.98 cm x 19.35 cm
- 1.1 kg
- Product Type
- LED display unit
- Energy Class
- Class B
- 27.5 Watt
- 14 W
- 20 kWh
- Diagonal Class
- 13"
- Commercial Use
- Combined With
- Touchscreen (multi touch)
- Series
- QBR Series
- Platform
- Tizen OS
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Dimensions
- Without stand
- 32.2 cm
- 2.98 cm
- 19.35 cm
- 1.1 kg
Display
- LCD Display Technology
- ADS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare
- Image Contrast Ratio
- 600:1
- Dynamic Contrast Ratio
- 10000:1
- Brightness
- 250 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 10
- Response Time
- 8 ms
- Operation Hours / Days
- 16 / 7
Stands & Mounts
- Flat Panel Mount Interface
- 100 x 100 mm
- VESA Compatibility
Media Player
- USB Port
- USB Ports Qty
- 2
Network & Internet Multimedia
- Connectivity
- Wi-Fi, LAN
- Connector Type
- HDMI input , 2 x USB , Audio line-out , RS-232 input , LAN
- UL, VCCI, C-Tick, BSMI, NOM, SASO, CB, AS/NZS 60950-1, CCC, EMC, PSB, IRAM, IEC 60950-1, EN 60950-1, KCC, KC, EMC Class B, NOM-019-SCFI-1998, K60950-1, EAC, NOM-001-SCFI-1993 IRAM, RCM, IP5X, IS13252, GB 17625.1-2012, INMETRO, FCC Part 15 Class B, GB 4943.1-2011, KN32, KN35, CNS 14336-1, VCCI-CISPR 32:2016, AS/NZS CISPR 32:2015, RoHS CNS 15663, GB/T9254-2008, CNS 13438 ITE EMI, ROCT CISPR 24-2013, ROCT CISPR 22:2005
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 37.6 cm
- Depth (Shipping)
- 24.8 cm
- Height (Shipping)
- 13.2 cm
- Weight (Shipping)
- 2 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
