Samsung PS43D450 - 43" 4 Series plasma TV - widescreen - HDTV - high-gloss charcoal black
Quicklinx: 7PBDWS00 Mfr#: PS43D450A2WXXU
  • 1080p
Being able to watch high definition TV shouldn't have to be a privilege. Introducing the Samsung Plasma TV Series 450, this entry-level Series provides you with all of the great features of a modern TV and at a great value.
  • Planet First
    Be a friend to the planet. Samsung's new TVs are constructed using more efficient technology, fewer components and non-toxic materials, so are kinder on the environment.
  • Connect Share Movie
    Tap your digital devices. ConnectShare Movie transforms your TV into a home entertainment theatre - simply plug in your USB memory drive or connect your hard disk drive to screen the movies, photos and music stored there.
  • Clear Image Panel
    Delivering the best picture possible is job one at Samsung. The Samsung's new TV line up uses a new filter & panel structure to eliminate layered images and produce clear images from almost every angle. This also eliminates the production of dual images and any form of blurring typically found with glass filters.
  • The ultimate home-base of entertainment
    High Definition Multimedia Interface inputs allow you to directly connect up to four devices, providing you with much more to watch and share. ConnectShare Movie lets you plug a separate drive directly into your TV so you can stream movies straight to its screen. BD Wise technology keeps your TV and connected Samsung Blu-ray player in constant communication for optimised performance.
  • Digital Noise Filter
    Watch crystal-clear analog programming as if it was being broadcasted digitally with Samsung's Digital Noise Filter. The filter helps to eliminate some of the digital “noise" that are seen on your screen.
Samsung PS43D450 - 43" plasma TV
19 kg
AC 230V ( 50/60 Hz )
Plasma TV
Diagonal Size
43" widescreen
High-gloss charcoal black
Resolution
1024 x 768
PC Interface
VGA (HD-15)
HDMI Ports Qty
3 port(s)
