Supercharged write speeds and trusted performance let you capture seamless 4K videos on your compatible phone or drone. Expanded storage gives you freedom to play more high-performance, intensive games on your tablet or gaming device.
Take your burst shot
Stunningly fast U3, Class 10 rated read/write speeds up to 180/130 MB/s, let you shoot more photos faster and transfer with ease. 4K videos look sharp with UHS-I, V30 rated speed and A2 rating provides more storage for apps and games. -
Add space, keep it all
Huge capacity of 512 GB gives you plenty of storage space. Shoot as many long takes and high-resolution photos as you want or load up on must-have apps and media. Now you've got the room. -
You're fully protected
6-way peace of mind. The PRO Plus takes on life's adventures with water, temperature, X-ray, magnet, drop, and wear-out protection. Your experiences are irreplaceable and deserve reliable storage.
 - Samsung PRO Plus MB-MD512SA - flash memory card - 512 GB - microSDXC UHS-I
- Product Type
 - Flash memory card
- Form Factor
 - microSDXC UHS-I Memory Card
- Storage Capacity
 - 512 GB
- Speed Rating
 - A2 / Video Class V30 / UHS-I U3
- Enclosure Colour
 - Blue
- Included Memory Adapter
 - microSDXC to SD adapter
 - 5-year warranty
- Product Type
 - Flash memory card
- Storage Capacity
 - 512 GB
- Enclosure Colour
 - Blue
- Speed Class
- Read Rate
 - Up to 180 MB/s
- Write Rate
 - Up to 130 MB/s
- Form Factor
 - Magnetic-proof, waterproof, X-ray-proof, temperature-proof, drop-proof, wear-resistant
 - Limited warranty - 5 years , Limited warranty - SD adapter - 1 year
 - 15 mm
 - 11 mm
- Thickness
 - 1 mm
 - 0.25 g
 - -25 °C
 - 85 °C
