Supercharged write speeds and trusted performance let you capture seamless 4K videos on your compatible phone or drone. Expanded storage gives you freedom to play more high-performance, intensive games on your tablet or gaming device.
                Take your burst shotStunningly fast U3, Class 10 rated read/write speeds up to 180/130 MB/s, let you shoot more photos faster and transfer with ease. 4K videos look sharp with UHS-I, V30 rated speed and A2 rating provides more storage for apps and games.
                Add space, keep it allHuge capacity of 256 GB gives you plenty of storage space. Shoot as many long takes and high-resolution photos as you want or load up on must-have apps and media. Now you've got the room.
                You're fully protected6-way peace of mind. The PRO Plus takes on life's adventures with water, temperature, X-ray, magnet, drop, and wear-out protection. Your experiences are irreplaceable and deserve reliable storage.
- Samsung PRO Plus MB-MD256SA - flash memory card - 256 GB - microSDXC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDXC UHS-I Memory Card
- Storage Capacity
- 256 GB
- Speed Rating
- A2 / Video Class V30 / UHS-I U3
- Enclosure Colour
- Blue
- Included Memory Adapter
- microSDXC to SD adapter
- 5-year warranty
- Product Type
- Flash memory card
- Storage Capacity
- 256 GB
- Enclosure Colour
- Blue
- Speed Class
- Read Rate
- Up to 180 MB/s
- Write Rate
- Up to 130 MB/s
- Form Factor
- Magnetic-proof, waterproof, X-ray-proof, temperature-proof, drop-proof, wear-resistant
- Limited warranty - 5 years , Limited warranty - SD adapter - 1 year
- 15 mm
- 11 mm
- Thickness
- 1 mm
- 0.25 g
- -25 °C
- 85 °C
