Samsung PM883 240GB 2.5" 7mm TLC Sata 6Gbps 2GB Cache SSD
Quicklinx: FY4VWS00 Mfr#: MZ7LH240HAHQ-00005
PM883 offers capacity of the competition while handling heavy mixed workloads with reduced latency. PM883 has various capacity up to 7.68 TB, faster sequential read speed, 550MB/s, and less TCO compared with conventional HDDs. This is suitable for various servers, including web, streaming, application and cache servers.
  • Enhanced durability
    With an MTBF of 2,000,000 hours and a robust shock & vibration tolerance, this SSD offers reliability for data storage.
  • Optimized performance
    Boasting a data transfer rate of 600 MBps and support for Native Command Queuing (NCQ), the drive ensures efficient handling of data requests.
  • Advanced security
    Equipped with 256-bit AES hardware encryption, the SSD provides high-level data protection, keeping your information secure from unauthorized access.
  • Energy efficient
    The SSD's power consumption is optimized for efficiency, using only 2.3 W during read operations and 1.3 W in idle mode, reducing energy costs.
  • High capacity storage
    With a 240 GB capacity and support for TRIM, the SSD maintains high-speed data access and long-term performance, making it ideal for extensive data storage needs.
Samsung PM883 MZ7LH240HAHQ - SSD - 240 GB - SATA 6Gb/s
Solid state drive - internal
240 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), TRIM support, Power Disable Pin (Pin3)
69.85 mm x 100.2 mm x 6.8 mm
70 g
240 GB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Bytes per Sector
512
69.85 mm
100.2 mm
6.8 mm
70 g
Performance
Drive Writes Per Day (DWPD)
1.3
SSD Endurance
341 TB
Data Transfer Rate Details
Serial ATA: 600 MB/s
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 320 MBps (write)
4KB Random Read
98000 IOPS
4KB Random Write
14000 IOPS
Average Latency
70 µs
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
2.3 Watt (read) , 3.6 Watt (write) , 1.3 Watt (idle)
RoHS
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine
Vibration Tolerance (non-operating)
20 g @ 20-2000 Hz
