Samsung's TIZEN-powered PMH series premium displays achieve peak performance all while maintaining a stylish and captivating design. The PMH series displays leverage elevated brightness and refined image sharpness to ensure a consistently clear presentation even in settings with variable lighting. Additionally, the PMH series displays achieve robust, 24/7 durability for dependable and uninterrupted operations. As a result, businesses can feel confident that their messages will be delivered exactly as intended anywhere and at any time.
The standalone displays' integrated centralized infrared receiver (IR) ensures easier and more flexible user control. All models can receive the IR signal on individual panels via central IR. Through tailored installation or mounting, users can navigate the IR functionality from various locations, further augmenting uninterrupted performance. Equipped with a non-glare frontal panel, the PMH series displays reduce natural and ambient light interference to ensure continuous readability in any location. Image visibility and information readability are deemed to be very high, because it is less reflective under light or sunlight, which poses no issues when used with QSR menu boards, or airport flight schedule boards with ample natural light.
Durable premium displays optimize operations and message quality in any environment
Samsung's TIZEN-powered PMH series premium displays achieve peak performance all while maintaining a stylish and captivating design. The PMH series displays leverage elevated brightness and refined image sharpness to ensure a consistently clear presentation even in settings with variable lighting. Additionally, the PMH series displays achieve robust, 24/7 durability for dependable and uninterrupted operations. As a result, businesses can feel confident that their messages will be delivered exactly as intended anywhere and at any time. -
Convenient display control through a centralized receiver
The standalone displays' integrated centralized infrared receiver (IR) ensures easier and more flexible user control. All models can receive the IR signal on individual panels via central IR. Through tailored installation or mounting, users can navigate the IR functionality from various locations, further augmenting uninterrupted performance. -
Brilliant, glare-free visual quality
- Samsung PM43H PMH Series - 43" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/360408
- Diagonal Class
- 43"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi
- PC Interface
- DVI, DisplayPort
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- Mega Dynamic Contrast Ratio
- USB
- 2 ports
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class G
- 154 Watt
- Power Consumption (On mode)
- 135 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 180 kWh
- Dimensions (WxDxH) - without stand
- 96.4 cm x 3.05 cm x 55.43 cm
- 9.5 kg
- Product Type
- Energy Class
- Class G
- 154 Watt
- 135 W
- Power Consumption SDR (On mode)
- 135 kWh/1000h
- 180 kWh
- Diagonal Class
- 43"
- Commercial Use
- Series
- PMH Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, DisplayPort
- Dimensions
- Without stand
- 96.4 cm
- 3.05 cm
- 55.43 cm
- 9.5 kg
Display
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Image Contrast Ratio
- 3000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- MagicInfo
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 200 x 200 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connector Type
- 2 x HDMI , DisplayPort input , DVI-I input , 2 x USB , Audio line-in , Audio line-out , Serial input , Serial output , Remote control input
- EMC Class A
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0 Watt
- Width (Shipping)
- 107.7 cm
- Depth (Shipping)
- 15.4 cm
- Height (Shipping)
- 66.1 cm
- Weight (Shipping)
- 12.5 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
