Samsung's PIM-HDBT LFD HDBaseT plug-in receiver helps to make LFD installations significantly simpler and less costly. Working with Samsung's LFDs which support the PIM module, the receiver enables all-in-one connectivity between HD video sources and remote displays through a single cable, delivering uncompressed HD video, audio, Ethernet and control signals.
- Samsung PIM-HDBT - video/audio/network extender - HDBaseT
- Video/audio/network extender
- Form Factor
- Plug-in module
- Data Link Protocol
- HDBaseT
- Max Transfer Distance
- 100 m
- 20 cm x 3.44 cm x 17.56 cm
- 1.2 kg
- Designed For
- Samsung DH40D, DH48D, DH55D, DM65D, DM75D, ED65C, ED75C, ED75D, ME95C
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- HDBaseT
- 100 m
- 1 x network - RJ-45 female , 1 x HDBaseT - RJ-45 female
- 20 cm
- 3.44 cm
- 17.56 cm
- 1.2 kg
- 10 °C
- 40 °C
- 10 - 80%
- Designed For
