Samsung P530 Intel Dual Core P4500 2GB RAM 250GB HDD DVDRW Windows 7 Pro/XP Pro Downgrade Laptop
Quicklinx: 6NB0WS00 Mfr#: NP-P530-JA01UK
  • Celeron
  • Microsoft Windows 7 Professional / XP Professional downgrade
  • IEEE 802.11n
The Samsung P530 notebooks provide exceptional all-round business value, usability and productivity, thanks to their practical and robust design and state of the art technology. Their rugged casing not only prevents accidental damage, but it is also covered with a unique Soft grip material that's comfortable to hold and prevents finger marks. Protecting your data is all the more important in today's world and using Samsung Recovery Solution allows you to back up and restore your data quickly from an internal or external hard drive, and should the worse happen and your notebook is lost or stolen, the unique Failsafe* software lets you track its location and encrypt, manage, retrieve or erase your vital data. You can even completely lock the device. *30 day trial
Use it with the pre-loaded Windows 7 Professional Operating System, or roll back to Windows XP Professional with the disk provided if you prefer.
Design for great value
The P530 is a powerful, yet affordable style leader. Offering great all-round value by combining outstanding quality and performance in an ultra-stylish design, the P530 delivers a more enjoyable and productive user experience.
See the bigger picture in HD
When you're moving fast it's easy to miss out on the detail. So the P530's 15.6" HD LED display provides the sharpest images and boldest colours. Its proper 16:9 aspect ratio also ensures the most accurate representation of HD and allows you to enjoy photo-like image quality, greater viewing angles and better text legibility, reducing eye strain and, therefore, increasing productivity.
Tough yet beautiful
Sleek design belies inner strength. Reliable and robust, the P-Series boasts a light-yet-tough rubberised chassis and non-slip casing, making the P530 well-equipped for portable working. As a result, this notebook is more than capable of withstanding the inevitable hardships of life on the move, which all translates into a measurably lower Total Cost of Ownership.
Samsung P530 - 15.6" - Celeron P4500 - 2 GB RAM - 250 GB HDD
Notebook
Operating System
Windows 7 Pro / XP Pro downgrade
Intel Celeron P4500 / 1.86 GHz / 2 MB Cache
2 GB DDR3 (1 x 2 GB)
Storage
250 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics
Integrated Webcam
802.11b/g/n, 10/100 Ethernet
6-cell
38 cm x 25.6 cm x 3.6 cm
2.5 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Region: United Kingdom
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
L2 - 2 MB
64-bit Computing
Front Side Bus
800 MHz
Chipset
Mobile Intel HM55 Express
RAM
2 GB (1 x 2 GB)
DDR3 SDRAM
Speed
1066 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
250 GB HDD SATA 1.5Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM fixed
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 4x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
SuperBright Non-Gloss
Audio & Video
Graphics Processor
Intel HD Graphics
Memory Allocation Technology
Dynamic Video Memory Technology 5.0
Camera
Resolution
0.3 Megapixel
Sound
Stereo speakers, microphone
High Definition Audio
Input
Keyboard, touchpad
Scrolling, Flat
Communications
Wireless
802.11b/g/n
Network Interface
10/100 Ethernet
6-cell Lithium Ion
4400 mAh
Connections & Expansion
VGA , HDMI , Headphone output , Microphone input , 3 x USB 2.0 , USB 2.0/eSATA , LAN
Memory Card Reader
3 in 1 (SD Card, MultiMediaCard, SDHC Card)
Software
Software Included
Adobe Acrobat Reader, McAfee VirusScan (Trial), Samsung Update Plus, Samsung Recovery Solution IV, SAMSUNG Support Center, CyberLink DVD Suite, Samsung Easy Battery Manager, Samsung Easy Network Manager, Samsung Easy Display Manager, Samsung Easy Speed Up Manager
Security lock slot (cable lock sold separately), system password, hard drive password
Localization
2.5 kg
