The Samsung USB 3.0 flash drive DUO features a streamlined shape, and a high-quality, durable, metal-based design. With both a standard and a micro-USB connection, it's the all-purpose drive for all you do. And with Samsung reliability, you know your data is safe.
When form and function collide
The Samsung USB 3.0 flash drive DUO features a streamlined shape, and a high-quality, durable, metal-based design. With both a standard and a micro-USB connection, it's the all-purpose drive for all you do. And with Samsung reliability, you know your data is safe. -
One sleek drive, two ways to use it
The DUO offers amazing flexibility, making it ideal for use with your smartphone, tablet and PC. You can store and transfer all your files, in style. -
Samsung reliability safeguards your data
This USB flash drive offers NAND flash technology. -
Multi-purpose memory
When you want flexibility, you need the Samsung USB 3.0 flash drive DUO. With both micro and standard USB, it's the all-purpose drive for desktops, laptops, mobile phones, and tablets.
- Samsung DUO MUF-64CB - USB flash drive - 64 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0 / micro USB
- Storage Capacity
- 64 GB
- Technology
- NAND Flash
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 64 GB
- Read Rate
- Up to 130 MB/s
- Interface Type
- Technology
- NAND Flash
- Shockproof, magnetic-proof, waterproof, X-ray-proof, metal body, protective cap
- Limited warranty - 5 years
- 16.1 mm
- 5.73 mm
- 36.6 mm
- 5.2 g
- 0 °C
- 60 °C
