Samsung OM75D-W 75" 1920x1080 VGA DVI HDMI DisplayPort SOC LED Large Format Display
Quicklinx: B4V7WS00 Mfr#: LH75OMDPWBC/EN
  • 1080p
Draw more visitors to your retail business by effectively delivering promotional messaging with excellent visibility. OMD series SMART Signage features high brightness and contrast ratio for superb visibility in various lighting environments. Even customers who are wearing polarized sunglasses can view messages with outstanding clarity and brightness, without the display-blindness effect typically experienced with LCD displays.
  • Deliver promotional messaging vividly with excellent visibility
  • Optimized brightness control
    Optimize brightness control while reducing display operating expenses and power consumption with an automatic brightness sensor. You can customize the maximum and minimum brightness to complement any environment and control expenses, while extending the life of the monitor.
  • Durability
    Present business messaging even when the display is exposed to sunlightdirectly and indirectly for reliable around-the-clock operation.OMD Series SMART Signage is mechanically designed and has undergone internal testing to endure heat.
  • Clutter-free installation
    An uncluttered and simplified digital signage configuration that delivers rich media content, enhanced operational efficiency and lower TCO.
  • Easily and professionally manage content from a mobile device
    Manage content conveniently from a mobile device with built-in Wi-Fi and MagicInfo solution, even when the displays are installed in difficult-to-access locations. MagicInfo enables professional management of multiple displays, and theMagicInfo Mobile application can be used on a tablet or other mobile device to easily deliver content to displays or to update the displays’ templates or content.
  • Sophisticated design
    Impress customers and reduce viewing distractions with a sophisticated design featuring a narrow bezel and slim depththat offers an elegant appearance. Slim bezels allow OMD series displays to be used in seamless video walls for stunning window and wall displays. And with slim-depth panels these stylish displays deliver efficient use of space while reducing separate housing design costs.
Samsung OM75D-W 75" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
75"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Max Number of Screens
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock
Speaker System
2 speakers
Remote control
Voltage
Energy Class
Class D
935 Watt
Power Consumption (On mode)
542 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
791 kWh
167.58 cm x 12.46 cm x 95.38 cm
48 kg
Energy Class
Class D
935 Watt
542 W
791 kWh
Diagonal Class
75"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor, brightness sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Portrait mode
Dimensions
Without stand
167.58 cm
12.46 cm
95.38 cm
48 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
5000:1
Brightness
2500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6 ms
Commercial Features
Button lock
Multiple Display Control (MDC), Lamp Error Detection, digital daisy chain, MagicInfo, anti-image retention, Smart Scheduling, MagicInfo Player-S2
Video Wall
100
Stands & Mounts
Flat Panel Mount Interface
900 x 600 mm
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , DisplayPort input , 2 x HDMI , Composite video / component video input , Audio line-in , DisplayPort output , Audio line-out
VGA cable
Plug and Play, UL, TUV, VCCI, C-Tick, BSMI, GOST, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, EN 60950-1, KCC, BSMI CNS 13438, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, GB 17625.1-2012, IEC60950-1, GB 4943.1-2011
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
181.5 cm
Depth (Shipping)
41.5 cm
Height (Shipping)
107.5 cm
Weight (Shipping)
60 kg
30 °C
10 - 80%
