Draw more visitors to your retail business by effectively delivering promotional messaging with excellent visibility. OMD series SMART Signage features high brightness and contrast ratio for superb visibility in various lighting environments. Even customers who are wearing polarized sunglasses can view messages with outstanding clarity and brightness, without the display-blindness effect typically experienced with LCD displays.
Deliver promotional messaging vividly with excellent visibility
Draw more visitors to your retail business by effectively delivering promotional messaging with excellent visibility. OMD series SMART Signage features high brightness and contrast ratio for superb visibility in various lighting environments. Even customers who are wearing polarized sunglasses can view messages with outstanding clarity and brightness, without the display-blindness effect typically experienced with LCD displays. -
Optimized brightness control
Optimize brightness control while reducing display operating expenses and power consumption with an automatic brightness sensor. You can customize the maximum and minimum brightness to complement any environment and control expenses, while extending the life of the monitor. -
Durability
Present business messaging even when the display is exposed to sunlightdirectly and indirectly for reliable around-the-clock operation.OMD Series SMART Signage is mechanically designed and has undergone internal testing to endure heat. -
Clutter-free installation
An uncluttered and simplified digital signage configuration that delivers rich media content, enhanced operational efficiency and lower TCO. -
Easily and professionally manage content from a mobile device
Manage content conveniently from a mobile device with built-in Wi-Fi and MagicInfo solution, even when the displays are installed in difficult-to-access locations. MagicInfo enables professional management of multiple displays, and theMagicInfo Mobile application can be used on a tablet or other mobile device to easily deliver content to displays or to update the displays’ templates or content. -
Sophisticated design
Impress customers and reduce viewing distractions with a sophisticated design featuring a narrow bezel and slim depththat offers an elegant appearance. Slim bezels allow OMD series displays to be used in seamless video walls for stunning window and wall displays. And with slim-depth panels these stylish displays deliver efficient use of space while reducing separate housing design costs.
- Samsung OM75D-K 75" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 75"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Max Number of Screens
- 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-PVA
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, SMART Signage Platform, SMART Signage Platform 2nd Generation
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class D
- 935 Watt
- Power Consumption (On mode)
- 542 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 791 kWh
- Dimensions (WxDxH) - without stand
- 167.58 cm x 12.31 cm x 95.38 cm
- 42.2 kg
- Product Type
- Energy Class
- Class D
- 935 Watt
- 542 W
- 791 kWh
- Diagonal Class
- 75"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor, brightness sensor
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode
- Dimensions
- Without stand
- 167.58 cm
- 12.31 cm
- 95.38 cm
- 42.2 kg
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 5000:1
- Brightness
- 2500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 6 ms
- Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, Lamp Error Detection, MagicInfo, anti-image retention, MagicInfo Lite
Video Wall
- 100
Stands & Mounts
- Flat Panel Mount Interface
- 900 x 600 mm
Remote Control
- Remote control
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connector Type
- VGA input , DVI-D input , DisplayPort input , 2 x HDMI , Composite video / component video input , Audio line-in , DisplayPort output , Audio line-out
- Cables Included
- VGA cable
- Plug and Play, UL, TUV, VCCI, C-Tick, BSMI, GOST, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, EN 60950-1, KCC, BSMI CNS 13438, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, GB 17625.1-2012, IEC60950-1, GB 4943.1-2011
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 181.5 cm
- Depth (Shipping)
- 41.5 cm
- Height (Shipping)
- 107.5 cm
- Weight (Shipping)
- 54.2 kg
- 0 °C
- 30 °C
- 10 - 80%
