Samsung OH75F 75" 1920x1080 HDMI LCD Large Format Display
Quicklinx: F9S3WS00 Mfr#: LH75OHFPLBC/EN
  • 1080p
The OHF series displays feature a thinly-designed, all-in-one composition which enables convenient and easy installation. A thorough package equips the displays for long-term performance, and has ingress protection, anti-reflection technology, vandalism defense and a highly-efficient cooling system, among others. In addition, an integrated power box condenses operational components and accommodates an ultra-slim frame. Through advanced thermal control functionality and a filter-free design, the OHF series displays operate at reduced energy consumption. An integrated heat exchanger modifies signage resources depending on the environment, and ultimately cuts costs for operators.
  • An all-encompassing array of pre-assembled, outdoor-ready features
  • Energy-efficient performance
Samsung OH75F OHF Series - 75" LED-backlit LCD display - Full HD - outdoor - for digital signage
LED-backlit LCD flat panel display - outdoor
Diagonal Class
75"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
S-PVA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
USB
Voltage
Energy Class
Class D
1400 watt
Power Consumption (On mode)
520 W
Energy Consumption per Year
721 kWh
177.48 cm x 12 cm x 105.34 cm
142 kg
Energy Class
Class D
1400 watt
520 W
721 kWh
Diagonal Class
75"
Commercial Use
Series
OHF Series
Outdoor
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
Protection
Weatherproof, vandal-proof
177.48 cm
12 cm
105.34 cm
142 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
10000:1
Brightness
2500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6 ms
Stands & Mounts
Flat Panel Mount Interface
Media Player
USB Port
Network & Internet Multimedia
LAN
Connector Type
2 x HDMI , USB , HDBaseT , Audio line-out , Serial input , LAN
Security Slot Type
Kensington security slot
EMC, IEC 60529 IP56, IK10
Power supply
Input Voltage
Width (Shipping)
194.6 cm
Depth (Shipping)
49.5 cm
Height (Shipping)
125.2 cm
Weight (Shipping)
188 kg
-30 °C
50 °C
10 - 80% (non-condensing)
