The OHF series displays feature a thinly-designed, all-in-one composition which enables convenient and easy installation. A thorough package equips the displays for long-term performance, and has ingress protection, anti-reflection technology, vandalism defense and a highly-efficient cooling system, among others. In addition, an integrated power box condenses operational components and accommodates an ultra-slim frame. Through advanced thermal control functionality and a filter-free design, the OHF series displays operate at reduced energy consumption. An integrated heat exchanger modifies signage resources depending on the environment, and ultimately cuts costs for operators.
An all-encompassing array of pre-assembled, outdoor-ready features
The OHF series displays feature a thinly-designed, all-in-one composition which enables convenient and easy installation. A thorough package equips the displays for long-term performance, and has ingress protection, anti-reflection technology, vandalism defense and a highly-efficient cooling system, among others. In addition, an integrated power box condenses operational components and accommodates an ultra-slim frame. -
Energy-efficient performance
- Samsung OH75F OHF Series - 75" LED-backlit LCD display - Full HD - outdoor - for digital signage
- Product Type
- LED-backlit LCD flat panel display - outdoor
- Diagonal Class
- 75"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- Technology
- S-PVA
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- USB
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class D
- 1400 watt
- Power Consumption (On mode)
- 520 W
- Energy Consumption per Year
- 721 kWh
- 177.48 cm x 12 cm x 105.34 cm
- 142 kg
- Product Type
- Energy Class
- Class D
- 1400 watt
- 520 W
- 721 kWh
- Diagonal Class
- 75"
- Commercial Use
- Series
- OHF Series
- Outdoor
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Protection
- Weatherproof, vandal-proof
- 177.48 cm
- 12 cm
- 105.34 cm
- 142 kg
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Image Contrast Ratio
- 5000:1
- Dynamic Contrast Ratio
- 10000:1
- Brightness
- 2500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 6 ms
Stands & Mounts
- Flat Panel Mount Interface
Media Player
- USB Port
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- 2 x HDMI , USB , HDBaseT , Audio line-out , Serial input , LAN
- Security Slot Type
- Kensington security slot
- EMC, IEC 60529 IP56, IK10
- Power Device
- Power supply
- Input Voltage
- Width (Shipping)
- 194.6 cm
- Depth (Shipping)
- 49.5 cm
- Height (Shipping)
- 125.2 cm
- Weight (Shipping)
- 188 kg
- -30 °C
- 50 °C
- 10 - 80% (non-condensing)
