Samsung Odyssey OLED G9 Gaming Monitor
Quicklinx: HHKWWS00 Mfr#: LS49CG934SUXXU
Diagonal Size: 49in
Max Resolution: 5120 x 1440
Response Time: 0.03ms
Speakers: Speaker(s)
Interfaces: Micro HDMI, DisplayPort, HDMI
More than 50 In Stock
£1,165.84 ex VAT
£1,399.00 inc VAT
Samsung’s 49" Odyssey G9 gaming monitor is designed for exceptionally immersive gaming, and high productivity in any field. A 32:9 aspect screen, as wide as two quad high definition monitors, delivers maximum space to take in all the pin-sharp detail. It wraps around your field of vision with 1800R curvature to put you fully into your character's shoes. Plus, you can open multiple windows at once and game, watch and chat, all at the same time.
Dual QHD and OLED HDR screen This monitor has a Dual QHD (5120 x 1440p) resolution screen, plus a stupendously fast 0.03ms response time, and a 240Hz refresh rate. The OLED screen enhanced with the Neo Quantum Processor Pro brings brighter whites, deeper blacks and near infinite colour contrast.
AMD FreeSync Premium Pro Fast-action and complex game scenes are stable and stutter-free with AMD FreeSync Premium Pro for your competitive edge.
Multiple ports including HDMI 2.1 As the monitor has both HDMI 2.1 and Display ports, you can easily hook up a desktop computer, laptop or games console.
Eye care Eye Saver Mode minimises blue light enough to keep eyes relaxed and comfortable when gaming for extended periods. And Flicker Free technology continuously removes tiring and irritating screen flicker so you can focus longer with less distraction or eye strain
  • OLED picture quality
    Feel the difference of Samsung OLED. A brighter screen delivers more colors, shades and contrast for a more brilliant picture at all times, powered by Quantum Dot technology. Vibrant vistas will come to life in whole better ways.
  • 49" dual QHD
    Immense worlds envelop you through a super ultrawide display. A screen as wide as two quad high definition monitors delivers maximum space to take in all the pin-sharp detail. It wraps around your field of vision with 1800R curvature to put you fully into your character's shoes.
  • DisplayHDR True Black 400
    Uncover every secret with infinite expression. See true black and dark colors on screen without pixel light bleed for supreme color and depth expression in every game.
  • 0.03 ms Response time and 240 Hz refresh rate
    Dodge, counter and engage faster than the rest. OLED technology delivers near instant reaction time with 0.03 ms response time. HDMI and DisplayPort connections keep you ahead of the competition with the 240 Hz refresh rate. Milliseconds matter when you face the best.
  • AMD FreeSync premium pro
    Hyper action made seamless. Fast-action and complex game scenes are projected stably and stutter-free with AMD FreeSync premium pro to power your competitive edge.
  • Versatile connectivity
    Tap into a multitude of input options. HDMI, DisplayPort and USB hub let you hook up to favorite devices that elevate your game with no mess.
  • Built-in speakers
    The built-in speakers keep your desk clean from the mess of wires and external speakers. Get all the audio cues to take your game to the next level without setting up any other equipment.
  • Auto Source Switch+
    With Auto Source Switch+, your monitor detects when connected devices are turned on and instantly switches to the other source signal. This helps you get to your game action faster without flipping through multiple input sources.
  • Picture-by-Picture
    Use your screen to its maximum potential, and team up with friends in a whole better way. Picture-by-Picture splits the screen in half, using two inputs at their native resolution.
  • Picture-in-Picture
    The Picture-in-Picture feature eliminates the need for a second monitor by giving you a sub-screen that's perfect for multitasking. Pull up chat windows, gaming tips, or any other content without taking your eyes off your main screen.
  • Slim metal design
    Upgrade your gaming station with razor-sharp design. Featuring a premium and modern metal finish measuring very thin, Odyssey OLED's unmatched design will suit your stylish sense.
  • CoreSync and Core lighting+
    Enhance your screen surroundings. With CoreSync technology, a game's on-screen colors are projected into your real world to further immerse you into the setting. With Core lighting+, add amazing color to your setup for an instant vibe shift.
  • Ergonomic stand
    Reach the height of winning. Tilt and adjust your monitor until all enemies are in perfect view. Your display can be moved freely so you can find total gaming comfort.
Samsung Odyssey OLED G9 S49CG934SU - G93SC Series - OLED monitor - curved - 49" - HDR
OLED monitor - 49"
Energy Class
Class G
Energy Consumption per Year
110 kWh
Curved Screen
Adaptive-Sync Technology
VESA Adaptive-Sync, AMD FreeSync Premium Pro
USB 3.0 hub
Aspect Ratio
32:9
Native Resolution
Dual Quad HD 5120 x 1440 at 240 Hz
Pixel Pitch
0.234 mm
Brightness
250 cd/m²
Contrast Ratio
1000000:1
HDR Capable
HDR10+ Gaming / DisplayHDR 400 True Black
Response Time
0.03 ms (grey-to-grey)
Gaming
Colour Support
1 billion colours
Colour Gamut
99% DCI-P3 (CIE 1976)
Input Connectors
DisplayPort, Micro HDMI, HDMI
Display Position Adjustments
Height, tilt
Silver
119.47 cm x 28.41 cm x 52.93 cm
12.6 kg
Display Type
OLED monitor / OLED
Energy Class
Class G
Energy Class (HDR)
Class G
110 kWh
Diagonal Size
49"
Curved Screen
Yes (1800R)
Built-in Devices
USB 3.0 hub
Aspect Ratio
32:9
Native Resolution
Pixel Pitch
0.234 mm
Brightness
250 cd/m²
Contrast Ratio
1000000:1
HDR Format
HDR10+ Gaming
HDR Certification
Colour Support
1 billion colours
Colour Gamut
Response Time
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Picture by picture, Eco-Mode, game mode, Black eQualizer, CustomColor Mode, FPS Mode, Flicker Free technology, RTS Mode, Image Size, Eye Saver Mode, Factory Tunning, Factory Calibration Report, Off Timer Plus, Sports Mode, Low Input Lag, Quantum Dot Technology, Super Arena Gaming UX, RPG Mode, Picture-in-Picture, Auto Source Switch+, ergonomic stand, CoreSync lighting design, Virtual AIM Point, Entertain Mode, Slim Metal Design, Core lighting+ design, Graphic Mode
Silver
119.47 cm x 28.41 cm x 52.93 cm - with stand
12.6 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
DisplayPort 1.4 , HDMI , Micro HDMI , 3 x USB 3.0
Mechanical
Height, tilt
Tilt Angle
-2/+15
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x micro-HDMI-HDMI cable , 1 x DisplayPort cable
75 kWh/1000h
Power Consumption HDR (On mode)
87 kWh/1000h
Power Consumption (Typical)
75 Watt
Power Consumption (Max)
220 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 119.47 cm - depth: 28.41 cm - height: 52.93 cm - weight: 12.6 kg , Without stand - width: 119.47 cm - depth: 18.08 cm - height: 36.5 cm - weight: 8.8 kg
Shipping Width
135.2 cm
Shipping Depth
24 cm
Shipping Height
47.4 cm
Shipping Weight
18.1 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 49in
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Samsung
Price Range Ex VAT: £1000 - £1500
