Samsung Odyssey OLED G9 Gaming Monitor
Quicklinx: HHKWWS00 Mfr#: LS49CG934SUXXU
Diagonal Size: 49in
Max Resolution: 5120 x 1440
Response Time: 0.03ms
Speakers: Speaker(s)
Interfaces: Micro HDMI, HDMI, DisplayPort
More than 50 In Stock
£1,165.84 ex VAT
£1,399.00 inc VAT
Samsung’s 49" Odyssey G9 gaming monitor is designed for exceptionally immersive gaming, and high productivity in any field. A 32:9 aspect screen, as wide as two quad high definition monitors, delivers maximum space to take in all the pin-sharp detail. It wraps around your field of vision with 1800R curvature to put you fully into your character's shoes. Plus, you can open multiple windows at once and game, watch and chat, all at the same time.
Dual QHD and OLED HDR screen This monitor has a Dual QHD (5120 x 1440p) resolution screen, plus a stupendously fast 0.03ms response time, and a 240Hz refresh rate. The OLED screen enhanced with the Neo Quantum Processor Pro brings brighter whites, deeper blacks and near infinite colour contrast.
AMD FreeSync Premium Pro Fast-action and complex game scenes are stable and stutter-free with AMD FreeSync Premium Pro for your competitive edge.
Multiple ports including HDMI 2.1 As the monitor has both HDMI 2.1 and Display ports, you can easily hook up a desktop computer, laptop or games console.
Eye care Eye Saver Mode minimises blue light enough to keep eyes relaxed and comfortable when gaming for extended periods. And Flicker Free technology continuously removes tiring and irritating screen flicker so you can focus longer with less distraction or eye strain
Samsung Odyssey OLED G9 S49CG934SU - G93SC Series - OLED monitor - curved - 49" - HDR
OLED monitor - 49"
Energy Class
Class G
Energy Consumption per Year
110 kWh
Curved Screen
Adaptive-Sync Technology
VESA Adaptive-Sync, AMD FreeSync Premium Pro
USB 3.0 hub
Aspect Ratio
32:9
Native Resolution
Dual Quad HD 5120 x 1440 at 240 Hz
Pixel Pitch
0.234 mm
Brightness
250 cd/m²
Contrast Ratio
1000000:1
HDR Capable
HDR10+ Gaming / DisplayHDR 400 True Black
Response Time
0.03 ms (grey-to-grey)
Gaming
Colour Support
1 billion colours
Colour Gamut
99% DCI-P3 (CIE 1976)
Input Connectors
DisplayPort, Micro HDMI, HDMI
Display Position Adjustments
Height, tilt
Silver
119.47 cm x 28.41 cm x 52.93 cm
12.6 kg
Display Type
OLED monitor / OLED
Energy Class
Class G
Energy Class (HDR)
Class G
110 kWh
Diagonal Size
49"
Curved Screen
Yes (1800R)
Built-in Devices
USB 3.0 hub
Aspect Ratio
32:9
Native Resolution
Pixel Pitch
0.234 mm
Brightness
250 cd/m²
Contrast Ratio
1000000:1
HDR Format
HDR10+ Gaming
HDR Certification
Colour Support
1 billion colours
Colour Gamut
Response Time
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Picture by picture, Eco-Mode, game mode, Black eQualizer, CustomColor Mode, FPS Mode, Flicker Free technology, RTS Mode, Image Size, Eye Saver Mode, Factory Tunning, Factory Calibration Report, Off Timer Plus, Sports Mode, Low Input Lag, Quantum Dot Technology, Super Arena Gaming UX, RPG Mode, Picture-in-Picture, Auto Source Switch+, ergonomic stand, CoreSync lighting design, Virtual AIM Point, Entertain Mode, Slim Metal Design, Core lighting+ design, Graphic Mode
Silver
119.47 cm x 28.41 cm x 52.93 cm - with stand
12.6 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
DisplayPort 1.4 , HDMI , Micro HDMI , 3 x USB 3.0
Mechanical
Height, tilt
Tilt Angle
-2/+15
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x micro-HDMI-HDMI cable , 1 x DisplayPort cable
75 kWh/1000h
Power Consumption HDR (On mode)
87 kWh/1000h
Power Consumption (Typical)
75 Watt
Power Consumption (Max)
220 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 119.47 cm - depth: 28.41 cm - height: 52.93 cm - weight: 12.6 kg , Without stand - width: 119.47 cm - depth: 18.08 cm - height: 36.5 cm - weight: 8.8 kg
Shipping Width
135.2 cm
Shipping Depth
24 cm
Shipping Height
47.4 cm
Shipping Weight
18.1 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 49in
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Samsung
Price Range Ex VAT: £1000 - £1500
