Samsung NX2000 20.3MP Camera  Built in WI-FI
Quicklinx: 915CWS00 Mfr#: EV-NX2000BFWGB
  • microSDHC Card
  • microSD Card
The NX2000 boasts the largest screen in its class, with a stunning 3.7" (93.8 mm) WVGA display that serves up plenty of space for reviewing and editing your masterpieces. You get full touch-screen action, with no physical menu buttons taking up valuable real estate. The display offers up the full spectrum of colors, so what you see on the screen matches what you shoot.
The NX2000 takes photography to a whole new level by making it faster and easier to connect the camera to your smartphone or tablet with NFC (Near Field Communication). NFC automatically secures a Wi-Fi connection for you, so you can share what you capture.
  • 20.3-megapixel APS-C CMOS sensor
    You may not be a professional photographer, but with the 20.3-megapixel APS-C CMOS sensor, you can easily shoot like one. The sensor offers the highest resolution in its class to help you capture high-quality images with lifelike colors. And since the sensor is also the largest used in a mirrorless camera - measuring 23.5 mm x 15.6 mm - it collects the most light. That makes the sensor perfect for out focusing photography, and for shooting images without noise in low-light situations.
  • 3.7" WVGA touch screen
  • AutoShare
    Simultaneously send every picture you take to your mobile phone via Wi-Fi connection - to make backing up and sharing your high-quality photos super easy. Set up AutoShare once and the camera saves it as the default setting. AutoShare also GPS tags your photos with your Smart Phone.
  • Remote viewfinder
    Control your camera by using your smartphone as the viewfinder. Remote viewfinder lets you preview images, adjust the camera settings, zoom in and out and frame each scene - all from your phone, wirelessly.
  • Samsung Link
    Samsung Link lets you connect to all devices that support Samsung Link. You can wirelessly stream photos and videos from your camera to nearby devices to share with friends and family at once, or simply upload to web storage instantly for easy management. Enjoy the freedom of sharing with Samsung Link!
  • Cloud
    With Cloud, you'll never run out of room in your memory card or lose valuable pictures, even on the go. Wirelessly save images to a cloud service such as Microsoft Skydrive or a regional cloud provider, then view them anytime on your smartphone, tablet or download them to your PC later.
  • Social sharing and email
    You can instantly email or post must-see images and videos to your favorite social networks. Just select and upload wherever you have a Wi-Fi connection, and then add tags and comments. Share with your Blogger followers, or post to Facebook, Picasa or YouTube - and many more social networks.
  • Auto backup
    Wirelessly transfer photos and movies to your PC or Mac. Simply choose AutoBackup and you're all set. All your photos and videos are transferred wirelessly and safely stored on to your computer. Feel free to delete photos from your camera knowing there's a duplicate set on your computer.
  • NFC
  • 3D still and movie recording
    The pictures you take will tell stories that rival those created by the pros. Smart mode setting such as waterfall and light trace enable you to photograph the beauty of cascading water or flowing light trails. Use Action Freeze to capture the fast-paced actions around you, or merge various exposures with Rich Tone to create evocative images. Let Creative Shot enhance the emotion of any scene or moment you capture.
  • 1080p 30p Full HD movie recording
    The Samsung SMART CAMERA NX2000 may not look like a camcorder, but it capably captures Full HD 1080/30p video. With uncompromising performance bolstered by an 18-200 mm lens and wide zoom capability, the Samsung SMART CAMERA NX2000 delivers smooth, professional-looking videos that play well on your HDTV. When you're ready for showtime, an HDMI interface lets you transmit your vision straight to the big screen.
  • 8 fps continuous shooting
    When you're shooting fast-moving action, effortlessly capture the entire sequence with a series of brilliantly clear stills. The Samsung SMART CAMERA NX2000 lets you shoot continuously at an ultra-fast rate of 8 frames per second to ensure you get the shot you want. The advanced autofocus system brings crystal clarity to fast-moving subjects, and a short shutter release lag helps you capture the fleeting moment before the subject moves out of frame.
  • ISO 100-25600
    Even in the dark, you can capture a natural-looking portrait with amazing color retention and detail. The upgraded Wide Range ISO of the NX2000 lets you shoot up to ISO 25600, making it more sensitive to light than the previous model, which produces much clearer images. Shoot in the dark - indoors and out - and enjoy photos with minimal noise and blurring.
Samsung SMART Camera NX2000 - digital camera NX 20-50mm II lens
Digital camera - 1080p - mirrorless system
Lens Included
NX 20-50mm II lens
Memory Card Slot
microSD card
Image Processor
DRIMeIV
Internal Storage
2 GB flash
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
20.3 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 2.5x zoom - 20 - 50 mm - f/3.5-5.6 i-Function
Focus Adjustment
Automatic, manual
Min Focus Distance
28 cm
Digital Zoom
2x
Camera Flash
Detachable flash
External Flash Name
Samsung SEF-8A
Display
LCD display - 3.7"
Supported Battery
Samsung BP1130 Li-ion rechargeable battery - 1130 mAh (included)
Composite video/audio, HDMI, USB 2.0
White
11.9 cm x 3.57 cm x 6.45 cm
228 g
Lens Included
NX 20-50mm II lens
Enclosure Colour
White
Sensor Resolution
20.3 Megapixel
Optical Sensor Type
CMOS
Total Pixels
21,600,000 pixels
Effective Sensor Resolution
20,300,000 pixels
Optical Sensor Size
APS-C (23.5 x 15.7 mm)
ISO (Max)
25600
Sensor Dust Reduction
Sensor Features
Dust Reduction (image sensor vibration)
Optical Zoom
2.5x
Digital Zoom
2x
Image Processor
DRIMeIV
Face Detection
Services and Applications
Cloud storage capability
Print Standard
DPOF support, Exif Print support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
35
AE/AF Control
Face-priority AF, Subject-tracking AF, Touch Area AF
Face Detection
Face-priority AF function
Digital Video Format
H.264
Image Recording Format
JPEG, RAW, MPO
1920 x 1080
Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Connectivity Features
Remote live view
Exposure & White Balance
Light Sensitivity
ISO auto, ISO 100-25600
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Metering Zones
221
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, night mode, macro, silhouette, fireworks, panorama assist, sunset, waterfall, beauty face, action freeze, rich tone, light trace, creative shot, best face
Special Effects
Cool, Negative, Vivid, Custom Effect, fisheye, soft focus, landscape, portrait, Water Colour, miniature, Calm, Classic, Forest, Retro, Vignetting, DeFog, Halftone Dots, Selective Colour, Wash Drawing, Oil Sketch, Ink Sketch, Acryl, Coloured pencil
Retouch
Face retouch
White Balance
Custom, automatic, presets
White Balance Presets
Cloudy, tungsten light, Flash, daylight, fluorescent light (daylight), fluorescent light (natural white), fluorescent light (white)
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±3 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps
White Balance Bracketing
X-sync Speed
1/180 sec
Exposure Range
EV 0-18 (ISO 100)
Lens System
Focal Length Equivalent to 35mm Camera
30.8 - 77mm
Focus Adjustment
Automatic, manual
Min Focus Distance
28 cm
Max View Angle
70.2 degree(s)
Zoom Adjustment
Manual
Lens Construction
8 groups / 9 elements
Filter Size
40.5 mm
Lens Mounting Type
Samsung NX
ED glass, aspherical lens, i-Function
Camera Flash
Camera Flash
Detachable flash
Guide Number (m / ISO 100)
8
Flash Modes
Fill-in mode, rear curtain sync, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator, flash +/- compensation
External Flash Name
Samsung SEF-8A
Additional Features
Continuous Shooting Speed
8 frames per second, 5 frames per second, 10 frames per second, 30 frames per second, 15 frames per second
Self-Timer Delay
2 - 30 sec
Flash Terminal
Hot shoe
Additional Features
Backlight Compensation (BLC), RGB primary colour filter, sharpness control, digital image rotation, histogram display, in-camera red-eye removal, resizing an image, saturation control, GPS ready, in-camera film editing, USB charging, HDR image enhancement technology, Touch Shutter technology, Smart AUTO, Lens Distortion Correction, Wi-Fi Direct
Display
3.7" LCD display
Display Format
1,152,000 pixels
Display Form Factor
Built-in
Touch Screen
Display Features
Colour control, contrast control
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 , Composite video/audio output , HDMI output
Software
Software
Drivers & Utilities, Adobe Photoshop Lightroom
Battery Type
Samsung BP1130 Lithium Ion
Details
Battery Life Details
Photo shooting - 340 shots , Video recording - 2.8 hours
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card, microSDHC UHS-I Memory Card, microSDXC UHS-I Card
Internal Storage
2 GB flash
Image Storage
RAW 5472 x 3648 , JPEG 5472 x 3648 , JPEG 3888 x 2592 , JPEG 2976 x 1984 , JPEG 1728 x 1152 , JPEG 2736 x 1824 , JPEG 5472 x 3080 , JPEG 3712 x 2088 , JPEG 2944 x 1656 , JPEG 1920 x 1080 , JPEG 3648 x 3648 , JPEG 2640 x 2640 , JPEG 2000 x 2000 , JPEG 1024 x 1024 , MPO 2688 x 1512 - 3D mode , MPO 1920 x 1080 - 3D mode
Video Capture
H.264 - 1920 x 1080 - 30 fps , H.264 - 1920 x 810 - 24 fps , H.264 - 1280 x 720 - 30 fps , H.264 - 640 x 480 - 30 fps , H.264 - 320 x 240 - 30 fps , H.264 - 1920 x 1080 - 30 fps - 3D
11.9 cm
3.57 cm
6.45 cm
228 g
5 - 85%
