Enjoy crystal clear images beyond the limits of the human eye. The precise color saturation and the high contrast of 5.7'' Quad HD Super AMOLED display will drive you to feel the fluent and vivid color as if you are looking with the naked eye. High resolution boasts tremendous viewing experience. Truly optimized for web-browsing and e-booking.
No worries in the dark, still capture the best moments. Shoot brighter and clearer images using Rear and Front camera. 3.7MP front-facing F1.9 lens camera, and a 16MP Smart OIS back camera provides you the best results for every moment of your life even in dark surroundings.
Multi-window, gain flexibility by managing multiple applications at once on a single screen using simple gestures.
Premium screen (Quad HD Super AMOLED display)
Enjoy crystal clear images beyond the limits of the human eye. The precise color saturation and the high contrast of 5.7'' Quad HD Super AMOLED display will drive you to feel the fluent and vivid color as if you are looking with the naked eye. High resolution boasts tremendous viewing experience. Truly optimized for web-browsing and e-booking. -
Bright and clear images with advanced camera
No worries in the dark, still capture the best moments. Shoot brighter and clearer images using Rear and Front camera. 3.7MP front-facing F1.9 lens camera, and a 16MP Smart OIS back camera provides you the best results for every moment of your life even in dark surroundings. -
Free flowing and natural multitasking - intuitive, for more convenience
Multi-window, gain flexibility by managing multiple applications at once on a single screen using simple gestures. -
Fast charging, high capacity - shortened recharge, lengthened use
Thanks to charging speed improvement, waiting times of Galaxy Note 4 have decreased significantly. Go from zero to 50% in around 30 minutes - usually a 55-minute process. All you have to do is plug in and get dressed after taking a relaxing shower. If you're running out of your time, use ultra power saving mode.
- Samsung Galaxy Note 4 - bronze gold - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-N910F
- Display
- OLED display - 2560 x 1440 pixels - 5.7" - Quad HD Super AMOLED
- Processor
- Qualcomm Snapdragon 805 2.7 GHz (quad-core)
- Memory
- RAM 3 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 128 GB
- Operating System
- Android 4.4 (KitKat)
- Main Camera
- 16 Megapixel focus: automatic
- Front Camera
- 3.7 Megapixel
- Service Provider
- Not specified
- SIM Card
- Micro SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
- Security Devices
- Fingerprint reader
- Messaging Services
- Google Hangouts, SMS, MMS
- Connectors
- 3.5 mm headset jack, Micro-USB
- Talk Time
- Up to 600 minutes
- Bronze gold
- 78.6 mm x 8.5 mm x 153.5 mm
- 176 g
- Specific Absorption Rate (SAR)
- 0.37 W/kg (head) , 0.38 W/kg (body)
- SAR Category (Belgium)
- A
- Product Type
- Smartphone
- SM-N910F
- Form Factor
- Touch
- 78.6 mm
- 8.5 mm
- 153.5 mm
- 176 g
- Body Colour
- Bronze gold
- SAR Value
- 0.38 W/kg (body), 0.37 W/kg (head)
- A
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Navigation
- A-GPS, GLONASS, BeiDou
- SIM Card Type
- Micro SIM
- Input Device
- Multi-touch
Messaging & Internet
- Supported Social Networks and Blogs
- Google+
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 17, Band 20
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700b, FDD 800 DD
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.1, ANT+/ANT
- Bluetooth Profiles
- HFP, HSP, OPP, PAN, A2DP, AVRCP, SAP, PBAP, MAP, HOGP
- Communication Features
- Mobile Email client, Internet browser
Phone Features
- Phone Functions
- Speakerphone, call timer, conference call, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, magnetometer, gyro sensor, hall sensor, gesture, RGB sensor, heart rate, SpO2 sensor, UV sensor
- Security Devices
- Additional Features
- DLNA Certified, multitasking, sharing media via DLNA, S Pen multi-input, Samsung Approved for Enterprise (SAFE), infrared remote control, Dual Camera function, Noise Cancellation Technology, Action Memo, Multi Window, MIMO technology, Ultra Power Saving Mode, Download booster, Screen Write, Drag and Drop mode, MirrorLink support, Image Clip, Smart Select, Dynamic Lock Screen
Organiser
- Personal Information Management
- Calendar, synchronization with PC, calculator, reminder, alarm clock
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, Ogg Vorbis, AMR, MP3, FLAC, XMF, AAC +, OGG, eAAC+, MIDI, M4A
- Supported Digital Video Standards
- MKV, VC-1, FLV, AVI, MPEG-4, WMV, ASF, 3GP, H.264, H.263, M4V, WebM, MP43
- Clock Speed
- 2.7 GHz
- Processor Core Qty
- Quad-core
- RAM
- 3 GB
- Internal Memory Capacity
- 32 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 128 GB
Front Camera
- Sensor Resolution
- 3.7 Megapixel
- Special Effects
- Beauty face
Main Camera
- Sensor Resolution
- 16 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Focus Adjustment
- Automatic
- Camera Modes
- Selfie mode, Shot & More, Virtual Tour Shot
- HDR Mode
- Auto HDR mode
- Light Source
- LED light
- Video Resolutions
- 3840 x 2160 (4K)
- Selective Focus, Photo note, Rear-Cam Selfie, Smart Stabilisation
Display
- OLED display
- Technology
- Diagonal Size
- 5.7"
- Display Resolution
- Display Format
- QHD
- Colour Depth
- 16.7 million colours
- Connector Type
- MHL (Micro-USB) - 11 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
- Technology
- Lithium Ion
- Capacity
- 3220 mAh
- Talk Time
- 600 minutes
- Run Time Details
- Talk (WCDMA): up to 600 min , Active online usage (WCDMA): up to 10 hrs , Active online usage (LTE): up to 11 hrs , Active online usage (Wi-Fi): up to 12 hrs , Playback (video): up to 14 hrs , Playback (audio): up to 82 hrs
- Included Accessories
- Stylus, power adapter
