Samsung's Smart MultiXpress M5370LX monochrome multifunction printer provides smart usability that allows users to work fast and efficiently with intuitive, easy-to-use controls, high performance and resource-efficient features.
Smart Touch
Touch to print, just like on a tablet. With the Samsung Smart UI Center, you'll get intuitiveness, usability and extendibility at the same time, for perfect compatibility with various devices. -
Easy to use
The Real Preview Function is available in preloaded applications such as Copy, Send and Box. You can further extend usability with direct web access through the web browser to quickly print various web contents, such as maps, pictures, emails and more without a PC. -
Comfort manage
Enhance the UI by arranging and managing the environment by user with My Page. Simply customize the My Page settings and Quick Menu for each user and you can keep track of an individual's usage, control accessibility and more. Administrators can also create quick custom apps directly on the devices. -
High scan rate and fast print processing
Dual-Scan ADF technology delivers high printing and scanning speeds. Powerful CPU provides the power and capacity to swiftly accomplish various print and copy jobs. -
High-quality print output
Samsung's unique Rendering Engine for Clean Page technology automatically sharpens the focus of both graphics and text to deliver sharp, clean output. With an exceptional resolution, your scans, printouts and company will always look professional.
- Samsung MultiXpress M5370LX - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 300000 pages
- Recommended Monthly Volume
- 15000 pages
- Max Copying Speed
- Up to 53 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 53 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Display
- 10.1"
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 98 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, card stock, cotton paper, punched paper, archive paper
- Standard Media Capacity
- 620 sheets
- Max Media Capacity
- 3240 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network
- Power
- AC 230 V
- 106.5 cm x 50.6 cm x 116.8 cm
- 49 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Laser - monochrome
- 300000 pages
- 15000 pages
- Display Diagonal Size
- 10.1"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 2 GB
- Max Supported Memory
- 2 GB
- Hard Disk Drive
- 320 GB
Copying
- Max Copying Speed
- Up to 53 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- Edge Erase, margin shift
Printing
- Up to 53 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.7
- First Print Out Time B/W
- 7.5 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
Document & Media Handling
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 98 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 98 x 148 mm, Oficio (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 620 sheets
- 3240 sheets
- 100 sheets
- 100 sheets
- ADF - 100 sheets , Paper cassette - 520 sheets size: 98 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 98 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 53 ppm (A4) - B/W , Printing: up to 55 ppm (Letter A) - B/W , Copying: up to 53 ppm (A4) - B/W , Copying: up to 55 ppm (Letter A) - B/W , Scanning: up to 53 ipm - B/W , Scanning: up to 80 ipm - B/W duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Apple Bonjour, IPsec, IP filtering, MAC address filtering
- Operating System Support
- HP-UX 11i v3, IBM AIX 5.1, IBM AIX 5.2, Sun Solaris 9, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, openSUSE 11.0, openSUSE 11.1, HP-UX 11.0, HP-UX 11i v2, Sun Solaris 10, IBM AIX 5.3, IBM AIX 6.1, openSUSE 11.2, openSUSE 11.3, Ubuntu Linux 10.04, MS Windows Server 2008 R2, Fedora 11, Fedora 12, Fedora 13, Fedora 14, Ubuntu Linux 10.10, openSUSE 11.4, Debian Linux 5.0, Red Hat Enterprise Linux 5, IBM AIX 7.1, HP-UX 11i v1, Red Hat Enterprise Linux 6, Ubuntu Linux 11.04, Fedora 15, Debian Linux 6.0, Ubuntu Linux 11.10, Ubuntu Linux 12.04, IBM AIX 5.4, openSUSE 12.1, Windows 8, Windows 8 64-bit, Fedora 16, Fedora 17, MS Windows Server 2012 x64 Edition, Fedora 18, openSUSE 12.2, openSUSE 12.3, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.5 - 10.9, Fedora 19, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Debian Linux 7.0, Debian Linux 7.1, Linux Mint 15, Sun Solaris 11
- Voltage Required
- AC 230 V
- 1000 Watt
- Power Consumption Sleep
- 1.5 Watt
- First Copy Out Time B/W
- 4.5 sec
- ENERGY STAR Certified
- Blue Angel Compliant
- 106.5 cm
- 50.6 cm
- 116.8 cm
- 49 kg
- Sound Emission
- 37 dBA (idle) / 58 dBA (operating)
