Samsung MultiXpress M4370LX MonoLaser Multifunction Printer
CALL YOUR ACCOUNT MANAGER FOR PRICING!
Quicklinx: B2Z0WS00 Mfr#: SL-M4370LX/SEE
It's all about convenience and flow. Your favorite applications such as copy, scan, send, box, job status, address book and help come preloaded while custom widgets provide instant access to frequently used functions.
Innovation and usability is built into the SMART MultiXpress M4370LX. The Samsung SMART UX center is the first smart Android printing UX that is intuitive, extendible and ensures compatibility with various Android -based devices.
The SMART MultiXpress M4370LX is equipped with Dual-Scan ADF technology that delivers faster scanning speeds of up to 55 single-sided image per minute (ipm) and a 1 GHz dual-core CPU that powers printing at 43 pages per minute (ppm). With high-performance speed printing, businesses can work smoothly and operate more efficiently.
  • Enjoy preloaded applications and widgets
  • Touch to print, just like on a tablet
  • Faster scanning and fuss-free printing
    The SMART MultiXpress M4370LX is equipped with Dual-Scan ADF technology that delivers faster scanning speeds of up to 55 single-sided image per minute (ipm). With high-performance speed printing, businesses can work smoothly and operate more efficiently.
  • Stand out with sharp, high-quality print output
    Samsung's unique Rendering Engine for Clean Page (ReCP) technology delivers sharper text and cleaner images. A superior resolution of 1200 x 1200 effective dpi ensures that everything you do will stand out.
  • Save resources with low TCO printing
    Reduce labor costs for heavy printing with ultra-high-yield toner cartridges and drums. Toners that yield 30000 standard B&W pages and drums that yield 100000 will lower your TCO and reduce waste.
  • Expand use with independent functions and extensibility
    The interface also provides the real preview function from preloaded applications such as copy, send and box. You can also get direct web access through the Android web browser to quickly print web content without a PC.
  • Create the printing environment that suits your needs with partner solutions
    Numerous certified partner solutions are available through the Samsung XOA platform for further customization.
  • Samsung's Business Core Printing Solutions (BCPS)
    Samsung's Business Core Printing Solutions (BCPS) work as efficiently as you do with secure, cost-effective print operations. These solutions require no dedicated server or IT resources and reduces unnecessary printing and supply use.
  • Samsung wireless & NFC printing option
    With Samsung wireless & NFC printing, you can simply tap your smart device to access various mobile printing solutions including user authentication, secure printing, easy wireless setup and device cloning.
  • Configurable devices for optimized performance
    The SMART MultiXpress M4370LX is unique configuration can accommodate businesses of all sizes and industries. Factory-provided modules serve as the foundation for adding various components and customizing with optional components.
Samsung MultiXpress M4370LX - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
250000 pages
Recommended Monthly Volume
10000 pages
Max Copying Speed
Up to 43 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 43 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Display
10.1"
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
98 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, card stock, cotton paper, punched paper, archive paper
Standard Media Capacity
620 sheets
Max Media Capacity
3240 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network, Rendering Engine for Clean Page (RECP) technology, Samsung SMART UX Centre
AC 230 V
63 cm x 50.6 cm x 63.6 cm
49 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Printing Technology
Laser - monochrome
250000 pages
10000 pages
Display Diagonal Size
10.1"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
2 GB
Max Supported Memory
2 GB
Hard Disk Drive
320 GB
Copying
Max Copying Speed
Up to 43 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Edge Erase, margin shift
Printing
Max Printing Speed
Up to 43 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.7
Automatic Duplexing
First Print Out Time B/W
8 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
4800 x 4800 dpi
Document & Media Handling
Original Type
Sheets
100 sheets
Min Media Size
98 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 98 x 148 mm, Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
620 sheets
Max Media Capacity
3240 sheets
100 sheets
100 sheets
ADF - 100 sheets , Paper cassette - 520 sheets size: 98 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 98 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 43 ppm (A4) - B/W , Printing: up to 45 ppm (Letter A) - B/W , Copying: up to 43 ppm (A4) - B/W , Copying: up to 45 ppm (Letter A) - B/W , Scanning: up to 43 ipm - B/W , Scanning: up to 70 ipm - B/W duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Apple Bonjour, IPsec, IP filtering, MAC address filtering
Operating System Support
HP-UX 11i v3, IBM AIX 5.1, IBM AIX 5.2, Sun Solaris 9, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, openSUSE 11.0, openSUSE 11.1, HP-UX 11.0, HP-UX 11i v2, Sun Solaris 10, IBM AIX 5.3, IBM AIX 6.1, openSUSE 11.2, openSUSE 11.3, Ubuntu Linux 10.04, MS Windows Server 2008 R2, Fedora 11, Fedora 12, Fedora 13, Fedora 14, Ubuntu Linux 10.10, openSUSE 11.4, Debian Linux 5.0, Red Hat Enterprise Linux 5, IBM AIX 7.1, HP-UX 11i v1, Red Hat Enterprise Linux 6, Ubuntu Linux 11.04, Fedora 15, Debian Linux 6.0, Ubuntu Linux 11.10, Ubuntu Linux 12.04, IBM AIX 5.4, openSUSE 12.1, Windows 8, Windows 8 64-bit, Fedora 16, Fedora 17, MS Windows Server 2012 x64 Edition, Fedora 18, openSUSE 12.2, openSUSE 12.3, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.5 - 10.9, Fedora 19, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Debian Linux 7.0, Debian Linux 7.1, Linux Mint 15, Sun Solaris 11
AC 230 V
1000 Watt
Power Consumption Sleep
1.5 Watt
First Copy Out Time B/W
5 sec
ENERGY STAR Certified
Blue Angel Compliant
63 cm
50.6 cm
63.6 cm
49 kg
Sound Emission
37 dBA (idle) / 58 dBA (operating)
