Use the intuitive Samsung SMART UX Center powered by Android. Access a range of preloaded applications and custom widgets, print fast at speeds of up to 25 ppm and boost productivity, get professional print results with high-quality output.
Super smart is now super simple
A way of printing for smart and innovative businesses. -
Touch to print, just like on a tablet
Innovation and usability is built into the SMART MultiXpress K4250RX. The Samsung SMART UX Center is the first smart Android printing UX that is intuitive, extendible and ensures compatibility with various Android -based devices. -
Enjoy preloaded applications and widgets
It's all about convenience and flow. Your favorite applications such as Copy, Scan / Send, Box, Job Status, Address Book and Help come preloaded while custom widgets provide instant access to frequently used functions. -
Faster printing
The SMART MultiXpress K4250RX is equipped with a 1 GHz dual-core CPU that powers printing at 25 pages per minute (ppm). With high-performance speed printing, businesses can work smoothly and operate more efficiently. -
Stand out with sharp, high-quality print output
Samsung's unique Rendering Engine for Clean Page (ReCP) technology delivers sharper text and cleaner images. A superior resolution of 1200 x 1200 effective dpi ensures that everything you do will stand out. -
Save resources with low TCO printing
Reduce labor costs for heavy printing with ultra-high-yield toner cartridges and drums. Toners that yield 35000 standard B&W pages and drums that yield 200000 will lower your TCO and reduce waste.
- Samsung MultiXpress K4250RX - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 5000 pages
- Max Copying Speed
- Up to 25 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 25 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Display
- 10.1"
- Original Size
- A3 (297 x 420 mm), Ledger (279 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 98 x 148 mm (min) - 297 x 432 mm (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, thin paper, thick paper, card stock, extra heavy-weight paper, glossy paper, cotton paper, punched paper, preprinted paper, archive paper
- Standard Media Capacity
- 1140 sheets
- Max Media Capacity
- 2180 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network, Rendering Engine for Clean Page (RECP) technology, Business Core Printing Solutions (BCPS), Samsung SMART UX Centre
- 56.6 cm x 61 cm x 82.9 cm
- 61.7 kg
- Laser - monochrome
- 100000 pages
- 5000 pages
- Display Diagonal Size
- 10.1"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 2 GB
- Max Supported Memory
- 2 GB
- Hard Disk Drive
- 320 GB
Copying
- Max Copying Speed
- Up to 25 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- ID Card Copy, Image Repeat, Poster Copy, Job Build
Printing
- Up to 25 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF
- First Print Out Time B/W
- 8.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 98 x 148 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm), 297 x 432 mm, 148.5 x 210 mm, 297 x 354 mm
- 1140 sheets
- 2180 sheets
- 100 sheets
- 500 sheets
- ADF - 100 sheets - A3/Ledger (297 x 432 mm) weight: 42 g/m² - 163 g/m² , 2 x paper cassette - 520 sheets size: 98 x 148 mm - 297 x 354 mm weight: 60 g/m² - 220 g/m² , Bypass tray - 100 sheets size: 98 x 148 mm - 297 x 432 mm weight: 60 g/m² - 176 g/m² , Output tray - 500 sheets
- Speed Details
- Printing: up to 25 ppm (A4) - B/W , Printing: up to 25 ppm (Letter A) - B/W , Copying: up to 25 ppm (A4) - B/W , Copying: up to 25 ppm (Letter A) - B/W , Scanning: up to 45 ipm - B/W , Scanning: up to 18 ipm - B/W duplex , Scanning: up to 45 ipm - colour , Scanning: up to 18 ipm - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Secure Print, SSL, TLS, IPsec, 802.1x, IP filtering, MAC address filtering
- Operating System Support
- HP-UX 11i v3, IBM AIX 5.1, IBM AIX 5.2, Sun Solaris 9, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, openSUSE 11.0, openSUSE 11.1, HP-UX 11.0, HP-UX 11i v2, Sun Solaris 10, IBM AIX 5.3, IBM AIX 6.1, openSUSE 11.2, openSUSE 11.3, Ubuntu Linux 10.04, MS Windows Server 2008 R2, Fedora 11, Fedora 12, Fedora 13, Fedora 14, Ubuntu Linux 10.10, openSUSE 11.4, Debian Linux 5.0, Red Hat Enterprise Linux 5, IBM AIX 7.1, HP-UX 11i v1, Red Hat Enterprise Linux 6, Ubuntu Linux 11.04, Fedora 15, Debian Linux 6.0, Ubuntu Linux 11.10, Ubuntu Linux 12.04, IBM AIX 5.4, openSUSE 12.1, MS Windows Server 2012, Windows 8, Windows 8 64-bit, Fedora 16, Fedora 17, MS Windows Server 2012 x64 Edition, Android, Fedora 18, openSUSE 12.2, openSUSE 12.3, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, Windows 8.1, Windows 8.1 64-bit, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.5 - 10.9, Fedora 19, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Debian Linux 7.0, Debian Linux 7.1, Linux Mint 15, Sun Solaris 11
- 1.3 kW
- Power Consumption Sleep
- 1.5 Watt
- First Copy Out Time B/W
- 6.2 sec
- 56.6 cm
- 61 cm
- 82.9 cm
- 61.7 kg
- Sound Emission
- 30 dBA (idle) / 53 dBA (operating)
