Samsung MD230X6 Widescreen LCD Eyefinity Monitor
Quicklinx: 74NZWS00 Mfr#: LS23MURHB/EN
The Samsung SyncMaster MD Series enables to you to enjoy an expansive visual experience. Up to 6 monitors can be set up on one stand, creating a seamless multi-display environment that allows you to appreciate a truly panoramic point of view. So, if only the best visual experience is good enough for you, then the MD230x6 is ready to show you exactly that.
  • Brilliant picture quality everywhere you look
    Complete your multi - display experience with the highest picture quality you can get — Full HD. The MD series offers a stunningly clear picture thanks to an incredible 3000:1 static contrast ratio and a 150000:1 dynamic contrast ratio. And with a wide angle view of 178° / 178°, the picture looks razor - sharp from every direction.
  • A commanding view is right before your eyes
    The Samsung MD series guarantees your view is seamless with a bezel that's seriously super - thin. In fact, the total width is only slightly more than 15.2mm while the total top to bottom width is only 17.6mm. The displays are easy to connect and with a slim frame, your view is not obstructed by a bezel. That means you'll see a smooth picture across multiple screens — and a spectacular view right in front of your eyes.
  • Flexible, customizable multi - display solution
    Each MD series display includes an ergonomic, custom stand which gives you total flexibility to play games, watch movies or design graphics just the way you want. It's height adjustable up to 100mm and includes a hinge that tilts inward at 30°. The stand even lets you assemble your multi - display in landscape or portrait form. How's that for a design that adapts to your needs?
  • The ultimate multi - display for ultimate multi - tasking
    With the Samsung MD Series you can increase your productivity — just like Bill Gates did: “On my desk I have three screens, synchronized to form a single desktop. Once you have that large display area, you'll never go back, because it has a direct impact on productivity." (Fortune, April 2006). And since the Samsung MD series is easy to set up you won't have to waste money on costly monitors, graphic cards, PCs, and cables. It's also available in bundles of three and six and includes a unique stand you can customize. Experience the ultimate all - encompassing view whether you're a power gamer or power player.
  • A customized, multi - display set in a box
    With three MD series packages to choose from it's easy to select the multi - display that's right for you. Not sure which one is right for you? The MD230 single screen is available. Ready to multi - task with a multi - display? The MD230X3 includes three screens and the option to easily switch between landscape and portrait. Interested in the ultimate multi - display unit? The MD230X6 comes with six high - performance screens.
Samsung MD230X6 - LCD monitor - Full HD (1080p) - 23"
LCD monitor - 23"
Number Of Screens
6
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 150000:1 (dynamic)
Response Time
8 ms
Colour Support
16.7 million colours
Display Position Adjustments
158.6 cm x 30.7 cm x 76 cm
43.1 kg
Microsoft Certification
Certified for Windows Vista
Display Type
LCD monitor / TFT active matrix
Diagonal Size
23"
Number Of Screens
6
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Multiple Display
43.1 kg
VGA , DVI-D , DisplayPort
Mechanical
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Wall mountable
Remote control
1 x DVI cable - 2 m , 1 x USB cable - 1 m
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Power Supply
Internal
Power Consumption (Typical)
276 Watt
Power Consumption Stand by / Sleep
6 Watt
Shipping Weight
50.2 kg
