Samsung M70B 32IN MONITOR WHITE
Quicklinx: HBCHWS00 Mfr#: LS32BM701UPXXU
Everything you need is right in your screen. Watch, work and chat - all without connecting a separate PC - with smart monitor. Your favorite content, productivity and video call apps are built-in for a simpler and more stylish desk setup that's a joy to use every time.
  • Watch, play, live in style
    Everything you need is right in your screen. Watch, work and chat - all without connecting a separate PC - with the Smart Monitor. Your favorite content, productivity and video call apps are built-in for a simpler and more stylish desk setup that's a joy to use every time.
  • Your favorite shows in your space
    Effortless entertainment. Enjoy Netflix, YouTube and other streaming services by simply connecting the monitor to Wi-Fi. Samsung TV Plus also offers free live and on-demand content with no downloads or sign-up needed, while Universal Guide provides personalized content recommendations.
  • SlimFit camera
    Jump into any conversation. The SlimFit camera with tilt functionality allows you to create the perfect angle while using your favorite video call apps like Google Duo, which can be accessed directly through the monitor. Plus, the camera cover and option to fully detach always protect your privacy.
  • Hub for your home, from any room
    Turn your Smart Monitor into a control center for the home by connecting it to your IoT home products with SmartThings. Relax by turning off the lights, pulling down the blinds and setting the thermostat to the perfect temperature all with the Smart Monitor for a perfectly relaxed evening.
  • Multiple voice assistants
    With the Far Field Voice feature, activate your voice assistant just by speaking. Directly command the monitor - even at a distance - and tell it what you need. It's as simple as that. The Smart Monitor supports both Bixby and Amazon Alexa.
  • Mobile connectivity
    Convenient connectivity. With AirPlay integration, you can wirelessly connect Apple devices to the Smart Monitor and view on a bigger screen. Enjoy your favorite content from an iPhone, iPad, and Mac on the Smart Monitor and even mirror apps, documents, and websites.
  • Optimal brightness, optimum enjoyment
    Sensational picture, day or night. Surrounding light is detected by a sensor to adjust brightness automatically with Adaptive Picture. Even in broad daylight, watch dark, gritty dramas without squinting and straining your eyes to see the picture.
  • Rich sound, real experiences
    With built-in speakers, the M5 provides rich and realistic sounds for a more immersive experience overall. Plus, the Adaptive Sound feature adjusts sound based on a range of content situations, from speech to music to ambient noise, delivering more refined and enjoyable sounds for every listener.
  • Connect with convenience
    The USB type-C port enables you to power up, transmit data, and even send display signals between devices with just one connection. Its single connection architecture brings an enjoyable work environment that's both clutter-free and stress-free.
  • Reveal the game's hidden sides
    Keep your eye on the win. Adjust your screen to discover hidden areas in game scenes with Ultrawide Game View. Now when you play soccer games, see more of the pitch right up to the goalposts. And in driving games, get a natural and encompassing view of the road ahead.
  • Where gaming comes together
    Expand your experiences. The newly added Gaming Hub means this versatile display allows you to watch movies, work and even play games with just a monitor. Access, browse and stream a wide selection of games - just turn on your Smart Monitor and play with no PC or console needed.
  • Quick, simple setup to seize the win
    Check and control game settings in an instant. You can easily view the status of the most important settings such as FPS or HDR. Modify response time or screen ratio, as well as the game picture mode without having to leave your game screen to keep you focused on your goal.
Samsung S32BM701UP - M70B Series - LED monitor - 4K - 32" - HDR
LED-backlit LCD monitor - 32" - Smart monitor
Energy Class
Class G
Energy Consumption per Year
48 kWh
USB 2.0 hub, 802.11a/b/g/n/ac network adapter, Bluetooth 5.2 adapter, USB PD 65 Watt
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1845 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
HDR Capable
HDR10
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, USB-C
Display Position Adjustments
Tilt
Voltage
AC 100-240 V
White
71.61 cm x 19.35 cm x 51.7 cm
6.8 kg
CEC
Display Type
LED-backlit LCD monitor / TFT active matrix - Smart monitor
Energy Class
Class G
Energy Class (HDR)
Class G
48 kWh
Diagonal Size
32"
Operating System
Tizen
Built-in Devices
USB Power Delivery
65 Watt
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1845 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
HDR Format
HDR10
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Game mode, ConnectShare, Intel Wireless Display (WiDi), Flicker Free technology, Eye Saver Mode, Factory Tunning, DLNA, Auto Source Switch+, Adaptive Picture, Tap View, Remote Access, Sound Mirroring, SmartThings App Support, Adaptive Sound, Game Bar 2.0, far-field voice interaction, IoT Hub, Mobile to Screen Mirroring, Super Ultrawide GameView
White
71.61 cm x 19.35 cm x 51.7 cm - with stand
6.8 kg
Audio
Speakers
2 x HDMI (HDCP 2.2) , USB-C (DisplayPort Alt Mode, data, power up to 65W) , 3 x USB 2.0
Mechanical
Tilt
Tilt Angle
-2/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Samsung DeX
Remote control
1 x HDMI cable
CEC
Security Slot Type
Kensington security slot
Input Voltage
AC 100-240 V
33 kWh/1000h
Power Consumption HDR (On mode)
57 kWh/1000h
Power Consumption (Typical)
33.2 Watt
Power Consumption (Max)
150 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Microsoft 365, Alexa, Google Duo, Samsung Workspace, Bixby Voice Assistant, Apple AirPlay 2
Dimensions & Weight Details
With stand - width: 71.61 cm - depth: 19.35 cm - height: 51.7 cm - weight: 6.8 kg , Without stand - width: 71.61 cm - depth: 4.18 cm - height: 42.45 cm - weight: 5.7 kg
Shipping Width
84.2 cm
Shipping Depth
13.3 cm
Shipping Height
48.7 cm
Shipping Weight
8.7 kg
10 °C
10 - 80% (non-condensing)
