Samsung HW-MS6500 Wireless Curved Soundbar - Black
Quicklinx: CXXTWS00 Mfr#: HW-MS6500/XU
  • Simple sounds beautiful
    Sound+ is simply beautiful. Samsung audio technologies deliver rich, room-filling home theater sound without the need for a separate subwoofer. With a premium curved design and an elegant single mount option, Sound+ becomes one with your TV and brings your entire home cinema experience together like never before.
  • Sound that fills the room and moves every listener
    Exclusive technologies blend advanced sound processing and precise speaker control to deliver just the right level of bass. Sound+ delivers all-around perfect sound, no matter where you are in the room thanks to Samsung's wide range tweeter.
  • Don't just hear it, feel it
    Distortion Canceling technology predicts and cancels out distortion before it happens. Multi-speaker control increases the power and depth of bass by precisely coordinating the movement of each speaker. The result is richer, more detailed bass.
  • Sweet anywhere you sit
    Virtually every spot is the sweet spot. Get consistently amazing sound everywhere in the room with Samsung's wide range tweeter, which covers a wide frequency range.
  • Get real, with HD audio
    Hear your music the way it was meant to be heard, with more nuance and depth. HD Audio preserves the quality and richness of the original sound through 96 kHz/24 bit high resolution audio.
  • Gain control with OneRemote
    The OneRemote from select 2017 Samsung TVs can manage many of the Soundbar's functions through the TV UI.
  • Seamless mount
    Sound+ becomes one with your TV with a single seamless mount solution. No need to make additional holes in your wall and you can use just one cable to power both devices.
  • Smart sound mode
    Select a sound mode, or let the soundbar choose for you. Sound+ automatically analyzes the content and gives you optimized sound.
  • Music comes alive with your voice
    Can't recall the title Enjoy your soundbar hands-free using Alexa voice control. Ask Alexa to play something by simply saying the title or a few lines of the song's lyrics. No matter what kind of music you're in the mood for, Alexa will find it.
  • Wireless connection with TV
    Connect your Soundbar to your Samsung TV with ease and without the clutter of wires via Bluetooth or Wi-Fi. You'll be able to enjoy all your content instantly with clearer, more impactful sound.
  • A truly seamless 4K experience
    With 4K Pass-through, a simple HDMI connection delivers the best in audio and picture quality. Connect any 4K video source like a UHD Blu-ray player, through the Samsung Sound+ soundbar to your TV for rich sound and 4K picture quality.
  • A better connection to your favorite music
    Whatever songs get your heart beating, Sound+ can stream them from your phone or tablet. Simply use Bluetooth or connect to Wi-Fi to play your music through Samsung's Multiroom App. Within moments, you'll be playing your favorites in a way.
  • Wireless surround sound ready
    The Wireless surround kit lets you expand your surround sound system easily without the mess of wires. Together with your soundbar, you can create a multi-channel system for a true surround sound experience.
  • The science of sound
    Tested and tuned at the renowned Samsung California audio lab, audio engineers applied methods of transduction and advanced computer modeling to give you perfectly balanced, room-filling sound.
Samsung Sound+ HW-MS6500 - sound bar - for home theatre - wireless
Sound bar - for home theatre
System Components
Sound bar
Speaker Type
Active
Continuous Power
180 Watt
Frequency Response
38 - 20000 Hz
Amplifier
Integrated
Bluetooth, Wi-Fi
Audio Formats
WAV, WMA, AAC, MP3, FLAC, OGG, ALAC
Speaker System Details
1 x sound bar 180 Watt
Speaker Details
Sound bar - stereo x 2 , Sound bar - centre channel
Dark titan
Built-in Decoders
Dolby Digital, DTS decoder
116 cm x 13 cm x 7.8 cm
6.5 kg
Enclosure Colour
Dark titan
Design Features
Curved
Speaker System
System Components
Sound bar
Speaker Type
Active
Continuous Power
180 Watt
Frequency Response
38 - 20000 Hz
Amplifier
Integrated
Bluetooth 4.0, IEEE 802.11b/g/n
Built-in Decoders
Audio Formats
Controls
EQ mode selector, power on/off
Speakers Included
1 x sound bar - 180 Watt
Speaker Details
Driver Details
Sound bar: 6 x full-range driver , Sound bar: 3 x tweeter driver
Connector Type
HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in , SPDIF input (TOS Link)
Remote control, wall mount
Power Source
AC power adapter
116 cm
13 cm
7.8 cm
6.5 kg
