Multi-Speaker Control Technology
Wireless Surround Sound Technology
2.0 Channel
6 Speaker Soundbar
450W
Get real, with HD Audio
Feel the sound and get into the action with stunningly realistic HD Audio. It preserves the quality and richness of the original sound through 96kHz/24 bit without down sampling.
Multi-speaker control
Get the ultimate sound experience. Powered by exclusive Samsung technology, multi-array speakers move simultaneously for more powerful bass.
Sweet spot anywhere you sit
Every spot is the sweet spot. Get consistently amazing sound everywhere in the room with the state-of-the-art Wide-range tweeter.
Music comes alive with your voice
Can't recall the title? Enjoy your soundbar hands-free using Alexa voice control. Ask Alexa to play something by simply saying the title or a few lines of the song's lyrics. No matter what kind of music you're in the mood for, Alexa will find it. -
Every spot is the sweet spot. Get consistently amazing sound everywhere in the room with the excellent wide-range tweeter. -
Feel the sound and get into the action with stunningly realistic HD Audio. It preserves the quality and richness of the original sound through 96 kHz / 24 bit without down sampling. -
Get the ultimate sound experience. Powered by exclusive Samsung technology, multi-array speakers move simultaneously for more powerful bass. -
Wireless connection with TV
Connect your soundbar to your Samsung TV easily with Bluetooth or Wi-Fi and remove the clutter caused by wires. You'll be able to enjoy all your content instantly with clearer, more impactful sound. -
Seamless mount
Keep it simple and clean. Mount the soundbar directly on your TV without needing to make additional holes in your wall. Use just one cable to power both devices and remove the need for multiple messy wires. -
Gain control with one
You don't need several remotes. For power, volume, and even for the sound effects, you can control key soundbar functions with a Samsung TV remote through your TV's UI. -
Smart sound mode
Select a sound mode, or let the soundbar choose for you. It automatically analyzes the sound and gives you amazing sounds optimized for your content.
- Samsung HW-MS550 - sound bar - for home theatre - wireless
- Product Type
- Sound bar - for home theatre - 2.0-channel
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth, Wi-Fi
- Audio Formats
- WAV, AAC, MP3, FLAC, OGG, ALAC
- Black
- Built-in Decoders
- Dolby Digital, DTS decoder
- 89 cm x 13.05 cm x 7.1 cm
- 5 kg
- Product Type
- Enclosure Colour
- Black
Speaker System
- Speaker Type
- Active
- Maximum Sampling Rate Supported
- 96 kHz
- High-Resolution Audio
- Multiroom
- Amplifier
- Integrated
- Bluetooth, Wi-Fi
- Recommended Placing
- Wall-mountable, under-the-TV
- Built-in Decoders
- Audio Formats
- Connector Type
- HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link)
- Included Accessories
- Digital audio cable (optical), remote control, wall mounting bracket
- 89 cm
- 13.05 cm
- 7.1 cm
- 5 kg
- Shipping Width
- 112.6 cm
- Shipping Depth
- 22.6 cm
- Shipping Height
- 14.8 cm
- Shipping Weight
- 7.5 kg
