Amazing sound with a beautifully soft curved design, this soundbar is the perfect match for your TV. Audibly remarkable, visually appealing.
Powerful bass
Don't let wires get in the way of your bass. Set the wireless subwoofer anywhere in your space and surround yourself with richer, deeper bass. -
Surround sound expansion
Surround sound expansion expands the listening area, both sideways and up, to emanate even and high-quality sound. You can enjoy great sound with truly immersive surround effects. -
Music streaming via Bluetooth
The soundbar uses Bluetooth for easy wireless connections to other devices. Enjoy music from your mobile in incredible audio quality anywhere, no strings attached.
- Samsung HW-M4501 - sound bar system - for home theatre - wireless
- Product Type
- Sound bar system - for home theatre - 2.1-channel
- System Components
- Subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 260 Watt
- Frequency Response
- 45 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Audio Formats
- WAV, WMA, AAC, MP3, FLAC, OGG
- Speaker System Details
- 1 x subwoofer 130 Watt 3 Ohm , 1 x sound bar 130 Watt 6 Ohm
- Silver
- Built-in Decoders
- Dolby Digital, DTS Digital Surround
- Sound Effects
- Surround Sound Expansion
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Product Type
- Enclosure Colour
- Silver
- Design Features
- Curved
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 260 Watt
- 45 - 20000 Hz
- Amplifier
- Integrated
- Sound Effects
- Bluetooth
- Built-in Decoders
- Audio Formats
- Speakers Included
- 1 x subwoofer - 130 Watt - 3 Ohm - wall-mountable - wireless , 1 x sound bar - 130 Watt - 6 Ohm
- Driver Details
- Subwoofer: subwoofer driver - 6.5"
- Connector Type
- HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in (mini-phone stereo 3.5 mm) , SPDIF input (TOS Link)
- Included Accessories
- Digital audio cable (optical), remote control, wall mounting bracket
Sustainability Information
- ENERGY STAR Certified
- Dimensions (WxDxH) / Weight Details
- Sound bar: 107.8 cm x 12.9 cm x 4.75 cm / 2.7 kg , Subwoofer: 17.9 cm x 29.95 cm x 35.3 cm / 4.6 kg
- Limited warranty - 1 year
