Samsung HW-K850 Cinematic Up-firing 3.1.2 Wireless Smart Soundbar with Dolby Atmos
More really is more
Hear pristine sound, even the minute details. With 11 built-in speakers, each with its own dedicated amplifier, the HW-K850 immerses you in incredibly clear sound from the very last raindrop to the complex symphony of the orchestra. The height channel of the specialised upfiring speakers will surround you with richer, more multi-dimensional audio.
Above and beyond
Multi-dimensional cinematic sound is no longer just for movie theaters. The HW-K850 gives you incredible 3.1.2 channel sound that doesn’t just surround you, it puts you deep into the action.
From ordinary to exceptional surround
Three words: dynamic movie night. Surround Sound Expansion Plus lets you upmix any content to enjoy in 3.1.2ch surround sound. Feel the sound come from all around and overhead as if you’re in the theatre. So, choose any movie, pick a night, and prepare to be blown away.
Sweet anywhere you sit
Finding the sweet spot just got a lot easier. With a wide-range tweeter, engineered by the Samsung Audio Lab, you’ll get consistently great sound wherever you sit. So even if you didn’t score the best seat in the room, you won’t miss a single decibel.
Get real, with HD Audio
Feel the sound and get into the action with stunningly realistic HD Audio. It preserves the quality and richness of the original sound using 96 ~ 192kHz/24bit sampling.
                Crystal clear sound from all aroundGet cinema style sound without leaving home. 11 built-in speakers including 2 upward-firing drivers and wireless sub deliver crystal clear sound that feels like it comes from all around, including above, like in the theater.
                Feel every dimensionDolby Atmos transports you into the story with moving audio that flows all around you with breathtaking realism. Rather than being constrained to channels, sounds exist as individual entities that are precisely placed and moved in three-dimensional space - including from above - putting you in the center of the action.
                A truly seamless 4K experienceWith 4K Pass-Through, a simple HDMI connection delivers great audio and picture quality. Connect any 4K video source like a UHD Blu-ray player, through the Samsung HW-K850 to your TV for rich sound and 4K picture quality.
                Connect wirelessly, seamlesslyDon't let messy wires get between you and your entertainment. The soundbar and subwoofer connect to each other wirelessly for seamless, rich, and dynamic sound.
- Samsung HW-K850 - sound bar system - for home theatre - wireless
- Product Type
- Sound bar system - for home theatre - 3.1.2-channel
- System Components
- Subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 360 Watt
- Amplifier
- Integrated
- Bluetooth, Wi-Fi
- DLNA
- Streaming Services
- Deezer, Napster, Spotify, TuneIn, JUKE, Murfie, Qobuz, 7Digital
- Audio Formats
- WAV, WMA, AAC, AIFF, MP3, FLAC, OGG, ALAC
- Speaker System Details
- 1 x sound bar 198 Watt , 1 x subwoofer 162 Watt
- Speaker Details
- Sound bar 11 - 18 Watt - 10% THD - 4 Ohm - active , Speaker - subwoofer - 162 Watt - 10% THD - 3 Ohm - active
- Black
- Built-in Decoders
- Dolby Digital Plus, Dolby TrueHD, DTS Digital Surround, Dolby Atmos
- 2-year warranty
- Product Type
- Enclosure Colour
- Black
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 360 Watt
- Maximum Sampling Rate Supported
- 192 kHz (WAV, FLAC)
- High-Resolution Audio
- Multiroom
- Amplifier
- Integrated
- Bluetooth, Wi-Fi
- DLNA
- Internet Streaming Services
- Built-in Decoders
- Audio Formats
- Controls
- Input selector, power on/off, volume
- Speakers Included
- 1 x sound bar - 198 Watt - wall-mountable , 1 x subwoofer - 162 Watt - wireless
- Speaker Details
- Driver Details
- Subwoofer: subwoofer driver - 8"
- Driver Details (2nd speaker)
- Sound bar: 11
- Connector Type
- 2 x HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Digital audio input (optical) (TOS Link) , Service (5 pin Micro-USB Type B)
- Included Accessories
- Mounting hardware, AC power adaptor, remote control, power cable, HDMI cable, batteries, wall mounting bracket
- Dimensions (WxDxH) / Weight Details
- Sound bar: 121.02 cm x 13.14 cm x 8.17 cm / 6.7 kg , Subwoofer: 20.39 cm x 41.43 cm x 39.9 cm / 9.6 kg
- Shipping Weight
- 20.7 kg
- Limited warranty - 2 years
