Samsung HW-K850 3.1.2Channel 360W Wireless Soundbar with Dolby Atmos
Quicklinx: D2BLWS00 Mfr#: HW-K850/XU
Select:
  • K850
Samsung HW-K850 Cinematic Up-firing 3.1.2 Wireless Smart Soundbar with Dolby Atmos
More really is more
Hear pristine sound, even the minute details. With 11 built-in speakers, each with its own dedicated amplifier, the HW-K850 immerses you in incredibly clear sound from the very last raindrop to the complex symphony of the orchestra. The height channel of the specialised upfiring speakers will surround you with richer, more multi-dimensional audio.
Above and beyond
Multi-dimensional cinematic sound is no longer just for movie theaters. The HW-K850 gives you incredible 3.1.2 channel sound that doesn’t just surround you, it puts you deep into the action.
From ordinary to exceptional surround
Three words: dynamic movie night. Surround Sound Expansion Plus lets you upmix any content to enjoy in 3.1.2ch surround sound. Feel the sound come from all around and overhead as if you’re in the theatre. So, choose any movie, pick a night, and prepare to be blown away.
Sweet anywhere you sit
Finding the sweet spot just got a lot easier. With a wide-range tweeter, engineered by the Samsung Audio Lab, you’ll get consistently great sound wherever you sit. So even if you didn’t score the best seat in the room, you won’t miss a single decibel.
Get real, with HD Audio
Feel the sound and get into the action with stunningly realistic HD Audio. It preserves the quality and richness of the original sound using 96 ~ 192kHz/24bit sampling.
  • Crystal clear sound from all around
    Get cinema style sound without leaving home. 11 built-in speakers including 2 upward-firing drivers and wireless sub deliver crystal clear sound that feels like it comes from all around, including above, like in the theater.
  • Feel every dimension
    Dolby Atmos transports you into the story with moving audio that flows all around you with breathtaking realism. Rather than being constrained to channels, sounds exist as individual entities that are precisely placed and moved in three-dimensional space - including from above - putting you in the center of the action.
  • A truly seamless 4K experience
    With 4K Pass-Through, a simple HDMI connection delivers great audio and picture quality. Connect any 4K video source like a UHD Blu-ray player, through the Samsung HW-K850 to your TV for rich sound and 4K picture quality.
  • Connect wirelessly, seamlessly
    Don't let messy wires get between you and your entertainment. The soundbar and subwoofer connect to each other wirelessly for seamless, rich, and dynamic sound.
Samsung HW-K850 - sound bar system - for home theatre - wireless
Sound bar system - for home theatre - 3.1.2-channel
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
360 Watt
Amplifier
Integrated
Bluetooth, Wi-Fi
DLNA
Streaming Services
Deezer, Napster, Spotify, TuneIn, JUKE, Murfie, Qobuz, 7Digital
Audio Formats
WAV, WMA, AAC, AIFF, MP3, FLAC, OGG, ALAC
Speaker System Details
1 x sound bar 198 Watt , 1 x subwoofer 162 Watt
Speaker Details
Sound bar 11 - 18 Watt - 10% THD - 4 Ohm - active , Speaker - subwoofer - 162 Watt - 10% THD - 3 Ohm - active
Built-in Decoders
Dolby Digital Plus, Dolby TrueHD, DTS Digital Surround, Dolby Atmos
Enclosure Colour
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
360 Watt
Maximum Sampling Rate Supported
192 kHz (WAV, FLAC)
High-Resolution Audio
Multiroom
Amplifier
Integrated
Bluetooth, Wi-Fi
DLNA
Internet Streaming Services
Built-in Decoders
Audio Formats
Controls
Input selector, power on/off, volume
Speakers Included
1 x sound bar - 198 Watt - wall-mountable , 1 x subwoofer - 162 Watt - wireless
Speaker Details
Driver Details
Subwoofer: subwoofer driver - 8"
Driver Details (2nd speaker)
Sound bar: 11
Connector Type
2 x HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Digital audio input (optical) (TOS Link) , Service (5 pin Micro-USB Type B)
Mounting hardware, AC power adaptor, remote control, power cable, HDMI cable, batteries, wall mounting bracket
Dimensions (WxDxH) / Weight Details
Sound bar: 121.02 cm x 13.14 cm x 8.17 cm / 6.7 kg , Subwoofer: 20.39 cm x 41.43 cm x 39.9 cm / 9.6 kg
Shipping Weight
20.7 kg
