Samsung HW-K651 Wireless Multiroom Soundbar with Centre Speaker
Quicklinx: CXZ1WS00 Mfr#: HW-K651/XU
Specifically constructed by the state-of-the-art audio lab with larger speaker capacity, improved active crossover and a dedicated center speaker, the product provides amazing vocal clarity.
  • Experience crystal-clear dialog
  • Dive in to crystal clear and detailed sound
    Six built-in speakers give this soundbar the depth and power to deliver a warm and detailed audio experience.
  • Create true surround sound without wires
    Enjoy the freedom to fill every room of your home with music by adding Samsung Multiroom speakers to the system or create your own wireless 5.1 surround system.
  • The wireless way to upgrade your TV sound
    Connect your Soundbar to your Samsung TV without wires and enjoy superb, powerful sound that brings programs, movies and music to life. TV has never sounded so good.
  • Enhanced surround sound from a wider range of listening positions
    Surround Sound Expansion expands the listening area sideways and up, so it is more realistic and coming directly from the screen. Now you can enjoy great sound with truly immersive surround effects.
  • Bluetooth Power On
    Now you can power on your audio system and control it from your smartphone with Bluetooth. After an initial pairing, you can quickly find the devices you want, wake them up, and stream your music.
Samsung HW-K651 - sound bar system - for home theatre - wireless
Sound bar system - for home theatre - 3.1-channel
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
340 Watt
Amplifier
Integrated
Bluetooth, Wi-Fi
DLNA
Audio Formats
WAV, WMA, AAC, MP3, FLAC, OGG
Speaker System Details
1 x sound bar 180 Watt , 1 x subwoofer 160 Watt 3 Ohm
Speaker Details
Sound bar - surround x 6 - 30 Watt - <10% THD - 8 Ohm - active , Speaker - subwoofer - 160 Watt - <10% THD - 3 Ohm - active
Silver
Built-in Decoders
Dolby Digital, DTS decoder
Sound Effects
1.175 m x 21 cm x 48.8 cm
12 kg
Enclosure Colour
Silver
Design Features
Flat design
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
340 Watt
Multiroom
Amplifier
Integrated
Sound Effects
Bluetooth, Wi-Fi
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
DLNA
Recommended Placing
Wall-mountable, under-the-TV
Built-in Decoders
Audio Formats
Controls
Input selector, power on/off, volume
Speakers Included
1 x sound bar - 180 Watt , 1 x subwoofer - 160 Watt - 3 Ohm - wireless
Speaker Details
Connector Type
HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link)
AC power adaptor, remote control, wall mounting brackets, power cable, 4 screws, audio (optical) cable
53 Watt
1.175 m
21 cm
48.8 cm
12 kg
Dimensions (WxDxH) / Weight Details
Sound bar: 1.01 m x 8.7 cm x 5.3 cm / 2.6 kg , Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg
