Specifically constructed by the state-of-the-art audio lab with larger speaker capacity, improved active crossover and a dedicated center speaker, the product provides amazing vocal clarity.
Experience crystal-clear dialog
Specifically constructed by the state-of-the-art audio lab with larger speaker capacity, improved active crossover and a dedicated center speaker, the product provides amazing vocal clarity. -
Dive in to crystal clear and detailed sound
Six built-in speakers give this soundbar the depth and power to deliver a warm and detailed audio experience. -
Create true surround sound without wires
Enjoy the freedom to fill every room of your home with music by adding Samsung Multiroom speakers to the system or create your own wireless 5.1 surround system. -
The wireless way to upgrade your TV sound
Connect your Soundbar to your Samsung TV without wires and enjoy superb, powerful sound that brings programs, movies and music to life. TV has never sounded so good. -
Enhanced surround sound from a wider range of listening positions
Surround Sound Expansion expands the listening area sideways and up, so it is more realistic and coming directly from the screen. Now you can enjoy great sound with truly immersive surround effects. -
Bluetooth Power On
Now you can power on your audio system and control it from your smartphone with Bluetooth. After an initial pairing, you can quickly find the devices you want, wake them up, and stream your music.
- Samsung HW-K651 - sound bar system - for home theatre - wireless
- Product Type
- Sound bar system - for home theatre - 3.1-channel
- System Components
- Subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 340 Watt
- Amplifier
- Integrated
- Bluetooth, Wi-Fi
- DLNA
- Audio Formats
- WAV, WMA, AAC, MP3, FLAC, OGG
- Speaker System Details
- 1 x sound bar 180 Watt , 1 x subwoofer 160 Watt 3 Ohm
- Speaker Details
- Sound bar - surround x 6 - 30 Watt - <10% THD - 8 Ohm - active , Speaker - subwoofer - 160 Watt - <10% THD - 3 Ohm - active
- Silver
- Built-in Decoders
- Dolby Digital, DTS decoder
- Sound Effects
- Surround Sound Expansion
- 1.175 m x 21 cm x 48.8 cm
- 12 kg
- Product Type
- Enclosure Colour
- Silver
- Design Features
- Flat design
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 340 Watt
- Multiroom
- Amplifier
- Integrated
- Sound Effects
- Bluetooth, Wi-Fi
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- DLNA
- Recommended Placing
- Wall-mountable, under-the-TV
- Built-in Decoders
- Audio Formats
- Controls
- Input selector, power on/off, volume
- Speakers Included
- 1 x sound bar - 180 Watt , 1 x subwoofer - 160 Watt - 3 Ohm - wireless
- Speaker Details
- Connector Type
- HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link)
- Included Accessories
- AC power adaptor, remote control, wall mounting brackets, power cable, 4 screws, audio (optical) cable
- 53 Watt
- 1.175 m
- 21 cm
- 48.8 cm
- 12 kg
- Dimensions (WxDxH) / Weight Details
- Sound bar: 1.01 m x 8.7 cm x 5.3 cm / 2.6 kg , Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg
