Samsung HW-J6501 Wireless 6.1 Channel Soundbar With Subwoofer-Silver
Quicklinx: CB1KWS00 Mfr#: HW-J6501
The sleek, sweeping arc of the curved sound bar is designed to pair beautifully with curved TV, bringing you the ultimate in immersive Samsung pictures sound. Stream sound from compatible TVs to your connected sound bar using convenient TV SoundConnect. With no need for messy cables, you can realize great sound with simple installation With no cables between it and the sound bar, you're free to place the active subwoofer where you want, and make the most of deep, powerful sound.
  • Made for each other
  • Stream your TVs sound
  • Deep bass, from anywhere in the room
Samsung HW-J6501 - sound bar system - for home theatre - wireless
Sound bar system - for home theatre - 6.1-channel
Media Content Source
USB-host
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
300 Watt
Amplifier
Integrated
Ethernet, Bluetooth, Wi-Fi
Audio Formats
WAV, WMA, AAC, MP3, FLAC, Apple Lossless, OGG
Speaker System Details
1 x sound bar 132 Watt , 1 x subwoofer 168 Watt
Speaker Details
Sound bar - surround x 6 - 22 Watt - 10% THD - 4 Ohm - active , Speaker - subwoofer - 168 Watt - 10% THD - 3 Ohm - active
Silver
Built-in Decoders
Dolby Digital
USB-host
Enclosure Colour
Silver
Enclosure Material
Aluminium
Design Features
Curved
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
300 Watt
Signal-To-Noise Ratio
65 dB
Amplifier
Integrated
Audio Return Channel (ARC) Capability
IEEE 802.3 (Ethernet), Bluetooth, Wi-Fi
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Recommended Placing
Wall-mountable, under-the-TV
Built-in Decoders
Dolby Digital
Audio Formats
Controls
Input selector, EQ mode selector, power on/off, volume
Additional Features
Audio Return Channel (ARC), Anynet+, TV SoundConnect technology
Speakers Included
1 x sound bar - 132 Watt - wireless , 1 x subwoofer - 168 Watt - wireless
Speaker Details
Driver Details
Subwoofer: subwoofer driver - 7"
Connector Type
HDMI input (19 pin HDMI Type A) , USB (4 PIN USB Type A) , Audio line-in (mini-phone stereo 3.5 mm) , SPDIF input (TOS Link) , HDMI output (19 pin HDMI Type A) , LAN (RJ-45)
Mounting hardware, power adapter, USB cable, remote control, HDMI cable, wall mounting bracket
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg , Sound bar: 107.8 cm x 12.9 cm x 4.75 cm / 2.4 kg
