Complement the images you see on screen with realistic, dramatic natural sound. 3D Sound Plus gets you more immersed into your movies and shows, delivering cinematic surround sound that will make you feel like you are part of the action. Get the freedom to connect your Soundbar to your Samsung TV automatically without wires, and enjoy superb powerful sound that brings programs, movies and music to life. TV has never sounded so good.
- Samsung HW-J355 - sound bar system - for home theatre - wireless
- Product Type
- Sound bar system - for home theatre - 2.1-channel
- Media Content Source
- USB-host
- System Components
- Subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 120 watt
- Amplifier
- Integrated
- Bluetooth
- Audio Formats
- WAV, WMA, AAC, MP3, FLAC, OGG
- Speaker System Details
- 1 x sound bar 60 watt 8 ohm , 1 x subwoofer 60 watt 3 ohm
- Speaker Details
- Sound bar - stereo x 2 - 30 watt - 10% THD - 8 ohm - active , Speaker - subwoofer - 60 watt - 10% THD - 3 ohm - active
- Built-in Decoders
- Dolby Digital, DTS decoder
- Product Type
- USB-host
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 120 watt
- Signal-To-Noise Ratio
- 60 dB
- Amplifier
- Integrated
- Bluetooth
- Built-in Decoders
- Audio Formats
- Controls
- Virtual Surround
- Additional Features
- Smartphone remote controlled, TV SoundConnect technology
- Speakers Included
- 1 x sound bar - 60 watt - 8 ohm - wall-mountable - wired , 1 x subwoofer - 60 watt - 3 ohm - wired
- Speaker Details
- Connector Type
- USB 2.0 (4 PIN USB Type A) , Audio line-in (mini-phone stereo 3.5 mm) , SPDIF input (TOS Link)
- Included Accessories
- AC power adaptor, USB cable, digital audio cable (optical), remote control, wall mounting brackets
- Power Source
- AC power adapter
- Dimensions (WxDxH) / Weight Details
- Sound bar: 94.3 cm x 6.5 cm x 5.8 cm / 1.6 kg , Subwoofer: 15.2 cm x 28.4 cm x 30 cm / 2.84 kg
