Form matches function with a simple, uncluttered modern design. This classic bar mobile features sleek matching color edging and a clean user interface. The unique scalloped surface back design provides better grip, while slim and compact dimensions make it easy to hold and carry. The rubber anti-dust keypad is both designed for utmost usability and offers a dust-resistance surface that keeps your handset clean and as good as new. Superior 5-way navigation key centralizes all the most popular functions on the phone into one convenient place, easy to control and use.
Simple & compact design
Form matches function with a simple, uncluttered modern design. This classic bar mobile features sleek matching color edging and a clean user interface. The unique scalloped surface back design provides better grip, while slim and compact dimensions make it easy to hold and carry. -
Convenient & easy to use
The rubber anti-dust keypad is both designed for utmost usability and offers a dust-resistance surface that keeps your handset clean and as good as new. Superior 5-way navigation key centralizes all the most popular functions on the phone into one convenient place, easy to control and use. -
Comfortable viewing
Indulge in a large full-size screen in clear vivid color - what a contrast to the drab b&w offered by other entry-level phones. No need to compromise your viewing experience when you can enjoy a generously sized display that is more readable, more crisp in full living color. Improved user interface with improved layout is easy to navigate and lets you move from screen to screen seamlessly. You'll enjoy an extra energy boost from the more powerful battery that provides longer talk time and longer usage between recharges. -
MP3 ringtones
Outfitted with MP3 ringtones for full and nice-sounding tones that alert you to incoming calls and messages.
- Samsung GT-E1200 - black - feature phone - GSM
- Product Type
- Feature phone
- Display
- LCD display - 128 x 128 pixels - 1.52" - TFT
- Processor
- 156 MHz
- Service Provider
- Not specified
- Form Factor
- Bar
- Messaging Services
- SMS
- Talk Time
- Up to 420 minutes
- Standby Time
- Up to 720 hours
- Black
- 45 mm x 13.5 mm x 108 mm
- 65.1 g
- Specific Absorption Rate (SAR)
- 0.87 W/kg (head) , 0.35 W/kg (body)
- SAR Category (Belgium)
- C
- Product Type
- Feature phone
- Form Factor
- Bar - Yes
- 45 mm
- 13.5 mm
- 108 mm
- 65.1 g
- Body Colour
- Black
- SAR Value
- 0.35 W/kg (body), 0.87 W/kg (head)
- C
Cellular
- Technology
- GSM
- Service Provider
- Not specified
Messaging & Internet
- SMS
Communications
- 2G Band
- 900 GSM, 1800 GSM
Phone Features
- Phone Functions
- Speakerphone, call timer, conference call, vibrating alert
- Additional Features
- Intelligent Typing (T9)
Organiser
- Personal Information Management
- Calendar, calculator, reminder, alarm clock
Media Player
- Supported Digital Audio Standards
- MP3, MIDI
- Clock Speed
- 156 MHz
Display
- LCD display
- Technology
- TFT
- Diagonal Size
- 1.52"
- Display Resolution
- 128 x 128 pixels
- Colour Depth
- 65,536 colours
- Capacity
- 800 mAh
- Talk Time
- 420 minutes
- Standby Time
- 720 hours
- Run Time Details
- Talk (GSM): up to 420 hrs , Standby (GSM): up to 720 hrs
- Included Accessories
- Power adapter
