Samsung Grade A Watch 6 Classic 43mm Silver
Quicklinx: J4HDWS00 Mfr#: 300031446
Device Type: Wearable Tech, galaxy watch6
Type: SmartWatch
Product Range: Samsung Galaxy
Product Model: Watch6 Classic
£107.50 ex VAT
£129.00 inc VAT
Express delivery Delivered on Tuesday
Meet the stylish smartwatch that looks and feels like a timeless timepiece. Bringing back the rotating bezel to add a tactile touch alongside the larger watch screen yet.
  • Bigger screen with a rotating bezel
    Look your great and see even more at a glance with a 30% larger screen. Plus a slimmer, rotating bezel that you can turn to easily access apps, stats and more. All packed into a sleek silhouette with the elevated style of a classic watch.
  • Sapphire crystal: clearly durable
    Expertly crafted with Sapphire crystal glass to keep your screen looking great while protecting it from bumps and scratches. And this fashion piece isn't afraid to get a little dirty with IP68 water and dust resistance.
  • A stylish spin on an iconic look
    Inspired by the iconic designs of vintage diving watches, the slim spinning bezel makes navigating apps easy and accurate with a simple turn of the dial. Its timeless design is sure to click with your impeccable sense of style, too.
  • Change out your look in a snap
    From boardroom to weight room, own your look with a band for any occasion - even easier to swap with one simple click. Then accent your look with digital faces to complete your outfit.
  • Track your period on your wrist
    Your Galaxy Watch6 Classic uses skin temperature readings, measured while you sleep, to help track your monthly period, ovulation cycle and fertility windows. All collected data is encrypted and stored securely on your own device, giving you control over your information.
  • Heart health made simple
    Get ahead of your heart health with heart monitoring. Your Galaxy Watch6 Classic periodically scans your heart rate to inform you when it's detected an irregular rhythm.
  • Keep your body in balance
    Stay in the know about your body with the advanced BIA sensor. Get readings on body fat, skeletal muscle, body water, Body Mass Index (BMI) and more - so you have all the stats to stay on track.
  • Detects a fall and sends for help
    Your Galaxy Watch6 Classic is on standby in case of an emergency. Fall Detection will catch when you've suffered a fall and send an SOS notification to your emergency contact if you need help.
  • Keep fitness goals on track
    Work out to your full potential with useful performance insights on duration, distance, calories burned and more. Galaxy Watch6 Classic automatically tracks popular activities, like running and swimming, and makes it simple to manually track over 90 additional exercises.
  • Target your ideal intensity
    Make every run count with personalized heart rate zones that let you train at different intensities to achieve your goals.
  • Stay connected on the go
    Have the power to call, text, play music and find your phone all from your wrist. Your Galaxy Watch6 Classic connects with your other Galaxy devices seamlessly so you can do more from anywhere.
  • Snap a photo with your watch
    Frame and snap the shot you want. Simply open up the camera app on your Watch and pinch the screen or twist the bezel to zoom in and out. Then pose, set a timer or tap to snap a shot.
  • Go phone-free with LTE
    Get out into the world without having to carry your phone with you. Call and text your friends, jam out to your favorite playlist and more with LTE connectivity.
  • Bring more and carry less
    Conveniently carry your payment cards, digital IDs, boarding passes and more in your Galaxy Watch6 Classic.
Samsung Galaxy Watch6 Classic smart watch with band - silver - 16 GB - silver
Smart watch
Manufacturer Model Number
SM-R950
Tracking Data
Distance, calories burned, activity, sleep activity, body composition, heart rate, steps taken, skin temperature, sleep quality score, ECG, REM phases
NFC, Wi-Fi, Bluetooth
Navigation
GPS/GLONASS/Galileo/BeiDou receiver
Display
Super AMOLED - 1.3" - 432 x 432 pixels - 330 ppi - always-on display
Samsung Exynos W930
Storage
16 GB
Operating System
Wear OS by Samsung
Case
Round - 43 mm - stainless steel
Band
Silver - band - hybrid eco-leather - size: S/M - changeable
Input
Touch screen, push buttons, rotating bezel
Notifications
Calendar, SMS, social apps, incoming calls, irregular rhythm
Fast charge, camera remote control, music playback control, Emergency SOS, Body composition measurement tool, Sleep Coaching, find phone function
Supported Host Device OS
Android
Rechargeable 300 mAh - WPC
Battery Run Time
Up to 40 hours
Silver
42.5 mm x 10.9 mm x 42.5 mm
52 g
0.177 W/kg (head) , 0.288 W/kg (limb)
Smart watch
SM-R950
Android 10 or later
Notifications
Navigation
Tracking Data
Modes
90+ exercise modes
Digital Player
MP3, M4A, 3GA, AAC, OGG, OGA, WAV, AMR, AWB
Audio Input
Microphone
Audio Output
Speaker
Operating System
Wear OS by Samsung
Wearing Style
Watch style
Feedback Type
Vibration alert, visual interface, audio alert
Clock Display
Set Goals
Silver
Sensors
Accelerometer, barometer, bioelectrical impedance analysis sensor, electrical heart sensor, gyro sensor, geomagnetic sensor, infrared temperature sensor, light sensor, optical heart sensor, hall sensor
Storage
16 GB
User Memory
7.1 GB
Display
Super AMOLED - colour
Resolution
432 x 432 pixels
Diagonal Size
1.3"
Pixel Density
330 ppi
Always On Display (AOD)
Colour Depth
24-bit (16.7 million colours)
Wireless Interface
NFC, IEEE 802.11a/b/g/n, Bluetooth 5.3
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Input Device
Touch sensitive screen, push buttons, rotating bezel
CPU
Manufacturer
Samsung
Exynos W930
Clock Speed
1.4 GHz
RAM
Size
2 GB
Rechargeable Battery
300 mAh
Wireless Charging
Wireless Charging Standards
WPC
Run Time (Up To)
40 hours
Run Time Details
Typical usage (AOD Off) - up to 40 hour(s) , Typical usage (AOD On) - up to 30 hour(s)
Smart Watch Case
Case Shape
Round
Case Size
43 mm
Crystal Type
Sapphire crystal
Band
Name
Band
Changeable
Size
S/M
Clasp Type
Buckle
Material
Hybrid eco-leather
Silver
42.5 mm
10.9 mm
42.5 mm
52 g
Preloaded Software
Google Maps, Samsung Wallet
Vibrating Alert
Body Material
Stainless steel
Protection
Water-resistant
IP68, MIL-STD 810H
Max Depth of Water Resistance
50 m
Device Type: galaxy watch6
Type: SmartWatch
Brand: Samsung
Stock Status: While stocks last
Stock Status: Clearance
