Grade A returned device
Looking for your next phone or tablet, but want to make your money go further? Try one of our Grade A devices and you’ll find amazing deals on some of the latest and greatest devices.
- 12 months warranty
- Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
The Samsung Galaxy A16 5G combines performance and versatile functionality in a sleek design. Powered by an 8-core Exynos 1330 processor with a clock speed of 2.4 GHz, this smartphone ensures smooth multitasking and efficient operation. With a 6.7-inch Full HD+ Super AMOLED display featuring a resolution of 2340 x 1080 pixels and a refresh rate of 90 Hz, visuals are vibrant and fluid, making it suitable for gaming and streaming. Capture stunning photos with a versatile camera system that includes a 50 megapixel main lens, a 5 megapixel ultra-wide camera, and a 2 megapixel macro lens. The front 13 megapixel camera allows for high-quality selfies. Additionally, the device is equipped with a 5000 mAh battery and Samsung Super Fast Charging technology, supporting the demands of daily use. With support for 5G connectivity and a dual-SIM setup, the Samsung Galaxy A16 5G is designed to keep users connected at all times.
Powerful performance
Equipped with an Exynos 1330 processor, the Samsung Galaxy A16 5G delivers swift performance with its 8-core architecture, allowing for seamless multitasking and smooth operation across applications. -
Stunning visuals
The 6.7-inch OLED display offers a vivid viewing experience with a resolution of 2340 x 1080 pixels and a pixel density of 387 PPI, ensuring content looks crisp and vibrant. -
Advanced camera system
Featuring a 50 megapixel main camera, a 5 megapixel ultra-wide lens, and a 2 megapixel macro lens, the camera system allows for diverse photography options, catering to various styles and situations. -
Long-lasting battery life
The 5000 mAh battery ensures that the device supports daily usage without frequent charging, combined with fast charging capabilities to quickly replenish power when needed. -
Enhanced security features
Offers robust security options with a side-mounted fingerprint reader and facial recognition technology, ensuring that personal data remains protected.
- Samsung Galaxy A16 5G - light green - 5G smartphone - 128 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- SM-A166B/DS
- Display
- OLED display - 2340 x 1080 pixels - 6.7" - 387 ppi - (90 Hz) - Super AMOLED
- Processor
- Samsung Exynos 1330 2.4 GHz (8-core)
- Memory
- RAM 4 GB / 128 GB
- Supported Memory Card
- microSDXC slot - up to 1.5 TB
- Operating System
- Android 14 with One UI 6.1
- Main Camera
- 50 Megapixel - f/1.8 - focus: automatic
- Second Camera
- 5 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- 2 Megapixel - f/2.4 - macro camera
- Front Camera
- 13 Megapixel f/2.0 - focus free
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Fingerprint reader (side), face recognition
- Connectors
- USB-C
- Protection
- Dust-resistant, water-resistant
- Light green
- 77.9 mm x 7.9 mm x 164.4 mm
- 200 g
- Repairability Index
- 8.4 (out of 10)
- Specific Absorption Rate (SAR)
- 0.381 W/kg (head) , 0.943 W/kg (body) , 2.14 W/kg (limb)
- 2-year warranty
- Product Type
- Smartphone
- SM-A166B/DS
- Form Factor
- Touch
- Protection
- 77.9 mm
- 7.9 mm
- 164.4 mm
- 200 g
- Body Colour
- Light green
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 14
- User Interface
- One UI 6.1
- Navigation
- GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- SIM Card Configuration Details
- Nano SIM + nano SIM/microSD
- Input Device
- Multi-touch
Communications
- Data Transmission
- 5G NR FR1, FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 17, Band 20, Band 28, Band 38, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700b, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n3, n7, n8, n20, n28, n38, n40, n41, n77, n78
- 5G NR Frequency
- FDD 2100, FDD 1800, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD 2300, TDD TD 2500, TDD TD 3700, TDD TD 3500
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.3
Phone Features
- Sensors
- Accelerometer, light sensor, geomagnetic sensor, gyro sensor
- Security Devices
- Additional Features
- 6 years of Security Updates, 6 generations of OS upgrades, Samsung Knox Vault, Samsung Smart Switch, Quick Share, Virtual Proximity Sensing, SmartThings Support
Media Player
- Supported Digital Audio Standards
- WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
- Dolby Atmos sound technology
- Clock Speed
- 2.4 GHz
- Processor Core Qty
- 8-core
- RAM
- 4 GB
- Internal Memory Capacity
- 128 GB
- User Memory
- 109.3 GB
- Supported Flash Memory Cards
- microSDHC, microSD, microSDXC - up to 1.5 TB
Front Camera
- Sensor Resolution
- 13 Megapixel
- Lens Aperture
- F/2.0
- Focus Adjustment
- Focus free
Main Camera
- Sensor Resolution
- 50 Megapixel
- Lens Aperture
- F/1.8
- Focus Adjustment
- Automatic
- Digital Zoom
- 10x
- Camera Modes
- Macro mode, night mode, Pro mode, AR lens, Panorama, Food, Portrait, Slow motion mode
- Light Source
- LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, Slo-mo video 1280 x 720 (720p) at 120 fps
- Scene Optimiser
Second Camera
- Sensor Resolution
- 5 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
Third Camera
- Sensor Resolution
- 2 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Macro camera
Display
- OLED display
- Technology
- Super AMOLED
- Diagonal Size
- 6.7"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 387 ppi
- Max Brightness
- 800 cd/m²
- Colour Depth
- 16 million colours
- Refresh Rate
- 90 Hz
- Infinity U Display
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 5000 mAh
- Fast Charging Technology
- Samsung Super Fast Charging
- Run Time Details
- Active online usage (4G): up to 15 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (wireless video): up to 18 hrs , Playback (wireless audio): up to 79 hrs
- Android Audio Streaming for Hearing Aid (ASHA), IP54
- Included Accessories
- SIM card removal tool, USB-C to USB-C cable
- Limited warranty - 2 years
Sustainability Information
- 8.4 (out of 10)
