Samsung Gear VR Virtual Reality Headset v2
Quicklinx: CM09WS00 Mfr#: SM-R323NBKABTU
Put on the Gear VR, and you're there in the moment. Amazing display, wide field of view, precise head-tracking and low latency bring reality to the virtual. Gear VR works seamlessly with smartphones. All you need to do is slip in your phone and you're free to take on the world and beyond. To reach new levels, a comfortable headset is a must. That's why with a wider interface, Gear VR is now lighter compared to the previous model. And with its larger touchpad, you get easy and accurate control.
Samsung Gear VR - SM-R323 - virtual reality headset for mobile phone
Virtual reality headset
Intended For
Mobile phone
Integrated Components
Accelerometer, gyroscope, proximity sensor
20.78 cm x 12.25 cm x 9.86 cm
345 g
Blue black
Galaxy Note5, S6, S6 edge, S7
Intended For
Mobile phone
20.78 cm
12.25 cm
9.86 cm
345 g
Blue black
Samsung Galaxy Note5, S6, S6 edge, S7
