Put on the Gear VR, and you're there in the moment. Amazing display, wide field of view, precise head-tracking and low latency bring reality to the virtual. Gear VR works seamlessly with smartphones. All you need to do is slip in your phone and you're free to take on the world and beyond. To reach new levels, a comfortable headset is a must. That's why with a wider interface, Gear VR is now lighter compared to the previous model. And with its larger touchpad, you get easy and accurate control.
- Samsung Gear VR - SM-R323 - virtual reality headset for mobile phone
- Product Type
- Virtual reality headset
- Intended For
- Mobile phone
- Integrated Components
- Accelerometer, gyroscope, proximity sensor
- 20.78 cm x 12.25 cm x 9.86 cm
- 345 g
- Blue black
- Designed For
- Galaxy Note5, S6, S6 edge, S7
- Product Type
- Intended For
- Mobile phone
- 20.78 cm
- 12.25 cm
- 9.86 cm
- 345 g
- Blue black
- Designed For
- Samsung Galaxy Note5, S6, S6 edge, S7
